Results 1 to 10 of 18
Thread: 17 Cummins
    Dec 2016
    Default 17 Cummins
    I have searched on here but no luck yet. Has anyone been able to unlock the ECM on a 17 truck? As far as I know the EFI software supports them, but bullydog hasn't yet released an update. Bullydog said that some tuning companies figured out the unlock before they did. Thought I'd ask.
    TIA
    Jordan
    Yes we do support the 2017's for tuning once unlocked.
    Not sure on BD's update but you could always send it to Fleece Performance for unlocking, they can do 17's.
    Dec 2016
    The whole ECM goes to Fleece, or they can remote tune them?
    Jordan
    The whole ECM needs to be shipped to them, but the tune security disable is permanent and can never be reversed back by an update.
    Lifetime Member Mitco39's Avatar
    Jan 2009
    Flash in a OEM 15 file, then do the unlock. Then flash in whatever file you want thereafter. We've done many to date.
    Nov 2010
    If the customer drives the truck after unlocking, they will have a DEF code until it's tuned for deletes
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    When did they change the DEF harness.. i think in 2015? Is the harness the same 15-17?
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jan 2009
    I believe 15-17 is the same yes, if you are not deleting it you will get a code because of it.
    Even if you go back to a true 17 file after BD unlocks it?
    Nov 2010
    Quote Originally Posted by Dmaxink View Post
    16+ don't have a ammonia sensor which is the code that trips when using a 13-15 stock file.
    Les Szmidt
    2007 5.9 Dodge Ram
  1. New to cummins - Where can I get stock cummins files?
    By GabrielMga in forum Cummins 6.7L
    Last Post: July 8th, 2016, 12:20 AM
  2. New to Cummins
    By Morgan73 in forum Cummins 6.7L
    Last Post: February 27th, 2015, 11:26 AM
  3. New 5.0L cummins
    By LORDDiESEL in forum General (Diesel)
    Last Post: August 21st, 2013, 10:57 AM
  4. V2 '03 Cummins
    By SRXtreme in forum FlashScan V2
    Last Post: January 21st, 2012, 09:29 AM
  5. Have the v2 for gm how to get for cummins?
    By kregelsmax in forum Purchase and Shipping
    Last Post: December 26th, 2011, 05:04 PM
