Results 1 to 10 of 19
Thread: IAT CAX File for 12587603 and 12212156
    Jul 2003
    Default IAT CAX File for 12587603 and 12212156
    This will help out a few people:
    12587603 / 040730005
    Code:
    [B9996]
    ;         Description
    DESC.001 = IAT Sensor Calibration Table
    DESC.002 =
    DESC.003 =
    DESC.004 =
    DESC.005 =
    ;         Seg Caption                              Major                        Minor                Vis Dis 2D Grp
    VIEW =      2 "IAT Sensor Calibration Table"           "IAT"             ""       1   2  0   0
    ;         Address(es)                      BitOff Bits Typ Inv
    ADDR =    F90A                                  0   16 SNM   0
    ;         Units      Factor         Offset Prec MinLimit MaxLimit MinUser  MaxUser
    SI_SLOT = "C"  0.0390625           0    3      -40      284      -40      284
    IM_SLOT = "F"  0.0703125           0    3      -40      543      -40      543
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =  "C"           "C"
    IM_COL =  "F"           "F"
    SI_ROW =  "% A/D"           "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50.00,56.25,62.50,68.75,75.00,81.25,87.50,93.75,100.00"
    IM_ROW =  "% A/D"           "0.00,6.25,12.50,18.75,25.00,31.25,37.50,43.75,50.00,56.25,62.50,68.75,75.00,81.25,87.50,93.75,100.00".
    12212156 02020005
    Code:
    [B9996]
    ;         Description
    DESC.002 =
    DESC.003 =
    DESC.004 =
    DESC.005 =
    ADDR =    E3BC                                  0   16 SNM   0
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =  "C"           "C"
    IM_COL =  "F"           "F"
    Hi Highlander,
    Thanks for posting.
    What does % A/D refer to (the axis looks a lot like TP%)...?
    May 2010
    Umm it seems to be for LS1B
    EFILive Tuner
    Yes, those are both LS1B OS's.
    Hi Highlander,
    Thanks for posting.
    Instead of %AD (taking it as meaning percentage of analog voltage range), do you want to make this axis the actual voltage range...?
    The vehicles using LS1B used 0-5V range for the IAT.
    Oct 2011
    Any updates on this? I want to use a card style maf but am unsure since I don't know what the units are.
    May 2010
    Hi Highlander
    For Which ECM is this ? I think E67 ?
    EFILive Tuner
    Hi Highlander
    EFILive has both IAT scalers in the software already for the E67.
    Is there a similar table/cax for the TPS?
    I.e can you modify the voltage scale to TPS position, would be handy in some conversions that use different tps or limited throttle blade movement.
    as an example, a friends burnout car uses a ford tps on a big and ugly hat and based on the position he only gets to 65% at wot. it would be good to re-calibrate the range for his to indicate 100%. I'm using 01290005
    Jul 2003
    There is for TPS scaling...
    A/C scaling too and a few others.
  1. Truck won't start with cos3. Runs fine with regular file. 12587603/04073003
    By RedlinePerformance in forum Custom Operating Systems
    Last Post: November 4th, 2016, 06:01 AM
  2. 12587603.pdf file
    By cyipher in forum Gen III V8 Specific
    Last Post: September 8th, 2011, 11:47 AM
  3. Looking for a 12212156 file
    By L31Sleeper in forum Custom Operating Systems
    Last Post: March 31st, 2010, 03:22 PM
