Results 1 to 10 of 11
Thread: Balance Rate Cylinder Number in EFI Live vs Firing Order?
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    Question Balance Rate Cylinder Number in EFI Live vs Firing Order?
    I need clarification on balance rate cylinder numbers in regards to logging BALRCYLx mm3 (x=cylinder 1-6).
    Based on the firing order of 1-5-3-6-2-4 for the 5.9 Cummins is EFI Live following that when you view the balance rate CYL numbers in a log or do they use 1-2-3-4-5-6 from the front of the engine or from firewall?
    As an example is BARCYL6 the 4th cylinder from the front or is it the first or last cylinder in the engine block if viewed from the radiator?
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
    Oct 2015
    Bump
    Joecar or Cindy?
    Sorry, I don't have any Cummins knowhow...
    if it's anything like the LSx , then it would be the reversed firing order... but this would be just assuming Cummins is the same
    Oct 2015
    Do you know who, from EFI Live, could answer accurately?
    Paul is the software developer, let me pm him.
    Oct 2015
    Thank You
    We've all been on holidays since Christmas, 4 weeks a year over here and it's the middle of Summer right now.
    Unfortunately I can't give you an exact answer on this, the balance rates in the ECM are just stored as Cyl 1 - 6 in numeric order, how that relates to the actual firing order I don't know.
    So on the 6.7L ECM on the wiring diagram the ECM output "Injector Control 1" goes to "Injector 1" on the engine....but there is no reference to what cylinder that actually is as far as firing order. Our scantool labels just match what the wiring diagrams call them.
    Oct 2015
    4 weeks, nice!!! Hope you enjoyed your time off.
    So you aren't sure how the Cyl numbers in the ECM translate to physical cylinder numbers in the engine?
    Quote Originally Posted by Move'n Up View Post
    Didn't take 4 weeks, still got some time up my sleeve.
    Yeah, maybe I over explained it
    Oct 2015
    Closing the loop on this one after further research.
    The answer is; EFI Live balance rates logging will show you the Cylinder number, BALRCYLx, based on Firing Order which as previously stated is 1-5-3-6-2-4 for the 5.9 Cummins as viewed from the front of the engine.
    Here's an example; BARCYL6 is the 4th cylinder from the front.
  1. LS1 PCM in a LT1 Car... changing firing order
    By Mean Green Z28 in forum Conversions / Aftermarket Parts
    Last Post: February 27th, 2016, 02:55 AM
  2. Alt firing order stock LBZ tune...
    By dmaxdavid in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 28th, 2014, 03:50 PM
  3. Alt firing order stock LBZ tune...
    By dmaxdavid in forum Diesel
    Last Post: October 28th, 2014, 02:57 PM
  4. Dumb question on firing order
    By cmkelly01 in forum Petrol / Gas
    Last Post: August 26th, 2014, 09:24 PM
  5. firing order change.
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: August 25th, 2014, 10:37 AM
