Hi guys,
I bought my FSV2 a couple of months ago but have only been using it for 2 weeks, tuning my VFII Commodore and it has been fine until I plugged it into my OBDII this morning to do a log after I installed a catch can.
The LCD screen is all pixilated and hard to read. If I tilt it on a very acute angle I can make it out. I thought this was very odd, so before I did my log I plugged it into my laptop to check firmware. All firmware up to date (updated 23.12.16) but the screen is still having the same issues while plugged into my laptop.
Can anyone suggest a possible cause and solution for this please? Do these things fail?
I have not dropped the unit or handled it poorly in any way. It has been stored in the garage with my laptop, we had some hot weather over the last couple of days but it wouldn't have been any hotter than around 28 degrees in the brick garage.
I did a search in the knowledge base and have tried to adjust the contrast of the display(which is set to 0 for some reason) but get the following error,
EDIT: I did the log I was intending to do but also noticed that the file name had reverted back to 0001. I had already logged up to 0009 so was expecting it it be 0010.
