Results 1 to 8 of 8
Thread: pilot injection and pilot timing tables?
    Apr 2014
    Default pilot injection and pilot timing tables?
    got a question on those two tables. in the process of building a motor in a customers 5.9 and going to see how much power can be squeezed out of it with cam, 6.7 head and single s467 on it with 100hp injectors and a stroker cp3. looking for some advice
    Oct 2014
    What's the question?
    Apr 2014
    would u adjust them for 50-100hp injectors in a 5.9
    Oct 2015
    Yes, with a single S467 and the other mods you mentioned in your first post you are definitely going to need to adjust them. My assumption is that this is going to be a street driven truck.
    Apr 2014
    it is a street driven truck
    Oct 2014
    Yea definitely adjust. Both timing and duration. I like to start with a bit more pilot timing and taper it down as load and main timing go up. Keeping pilot timing higher while main is low, and vise versa. For duration it's a bit more trial and error. With big injectors you can sometimes end up with a bit of a lope when coming down to idle if you don't drop duration down, or if you drop out too much pilot duration it can get a bit noisy. A bit of trial and error.
    Apr 2014
    ok I will give it a try and see how it does.
    Apr 2014
    well truck runs great but the tune levels do have rattle but at a different rpm per tune level. just now adjusting the tables. so shall see if it goes away.
  1. Pilot timing tables don't change in DSP files
    By THEFERMANATOR in forum Duramax LB7
    Last Post: January 24th, 2015, 08:01 AM
  2. Injection Timing / Pilot
    By Lennart in forum General (Diesel)
    Last Post: January 20th, 2012, 02:05 AM
  3. injection timing after pilot c,d?
    By SGFastMax in forum Duramax LB7
    Last Post: February 3rd, 2010, 02:35 PM
  4. Adding up pilot injection timing values
    By turbo_bu in forum General (Diesel)
    Last Post: January 28th, 2008, 03:19 AM
