Results 1 to 10 of 14
Thread: Problems with idle after AutoVE flash (again)
    Senior Member mtnman's Avatar
    Sep 2005
    Default Problems with idle after AutoVE flash (again)
    I've already got an SD Tune which was developed from following the AutoVE tuning tutorial. The LTFTs fell within the -4 to +4 range, so I was going to go through the tuning tutorial again using the current SD tune as a starter. I followed the tutorial, modifying the settings in the current SD tune, then flashed the tun into the truck. The truck wouldn't stay at idle even when giving it gas. There was the strong smell of gas, so I increased the initial B0101 table by 5% over instead of the recommended 15%, flashed the tune, same problem, truck wouldnt stay idled after cranking and there was the strong smell of gas again. I'm wondering, does this tuning tutorial have to start with a "stock" tune as opposed to a tune which has already been through the VE tuning process? I've gone over the settings about 5 times and everything seems to be set correctly in the SDAutoTune.tun file. I cant figure out why this is happening again. I went through all my notes for other values to modify in the tune and made those changes (increase C6101 by 100%, set C2903, C2904 and C2906 to zero,zero out B5001), but truck still wont idle. Have I left out a modification?
    2003 2500HD,E-Fans, LT headers, Corsa catback, Outlaw intake.
    Jun 2005
    When doing a SD tune for the first time, it is suggested that you increase the VE as a safety precaution. If you're working from an existing SD-tuned VE table after minor or no mods were made, then you don't have to do this. C6101 only needs to be increased 100% once as well. The tutorial is designed to help get you into SD mode safely the first time.
    After the first time, all you need to do is kill the MAF (high freq. fail to 0 & high freq. fail limit to 1) and copy the high ocatne spark table to the low octane table. If you want to turn the SES light off after killing the MAF, you can...but you don't have to. You can turn off DFCO, but you don't have to. I prefer to leave it on and filter it out of my logged data.
    At this point you're in CLSD (closed loop speed density), which means you still have LTFT's and STFT's trying to keep you at 14.63 unless PE kicks in. When tuning with a wideband, you need to get rid of these things. I prefer to leave PE enabled and set it to a single figure (like 12.2AFR across the board). Then in the Commanded Fuel In Open Loop table, command stoich (14.63) for all cells at all ECTs greater than 170* & less than 230*. To get rid of LTFT's, you disable them with {B3801}. STFT's are disabled by setting {B4205} Closed Loop Temp Enable to 256*.
    Now, you're in OLSD (open loop speed density) and are ready to log (once your vehicle has been at operating temps for a few minutes). Proceed with the AutoVE tuning.
    Once finished, re-enable the MAF settings (fail frequencies) and restore the low octane spark table. This will move you from OLSD to plain OL. You now need to tune the MAF. If you haven't already tuned the MAF, it's a good idea to increase the MAF table slightly (just like you did the first time with the VE table) as a safety precaution. Log your commanded AFR vs your WBO2 AFR for each MAF Frequency. The correction that needs to be made for each frequency is (WBO2_AFR/Comm_AFR). If you command 12.0 and read 13.0, you're lean - which means you need to increase the MAF table by 13/12 or 8.3% for that frequency. To dial it in closer, you can apply only half of the correction (4.2%) to avoid overshoot.
    Once the MAF is done, restore the stock closed loop temp enable & commanded fuel in open loop tables, enable LTFTs, and set your PE where you want it. I think that's all there is to it. Enjoy!
    Jun 2005
    SSPDemon,
    What do you add to filter out dfco cells? Use the current BEN Filter for throttle position / coolant temp and Add To Exclude Fuel Trim Cells Greater than 19?
    2000 Corvette Twin Turbo
    2004 CTS-V TVS 1900
    2006 TBSS TVS 1900
    All Tuned by
    Rad Tunes by Troy
    aka Vetteboy2k
    Sep 2005
    SSpdDmn,
    I think you misunderstood my question. I have successfully completed the Auto VE tutorial once. I followed the directions 2nd time around, starting with the Closed loop SD tune from the resulting previous Auto VE tune. My problem is that the truck cranks for about 3 seconds then shakes and cuts off, but there's the strong smell of gas. I've tried tunes with B0101 set at the original values, at 5%, at 8% and at 15%. The truck will not idle off a start with any of the VE table settings. It's worked once starting with a fairly stock Tune file, but now after starting with the SD tune, I cant even get the truck to stay idled after cranking it. I'm thinking there is some value that I've left out which needs to be modified. I cant find this value in my notes.
    Jul 2005
    Take a look at some of your tables, B3604 comes to mind to see if the numbers match the units. I've had 16 EQ in the forementioned table.
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Jun 2005
    Quote Originally Posted by vetteboy2k
    SSPDemon,
    yup...
    Jun 2005
    Quote Originally Posted by purrvert
    Ditto. 16.0 AFR vs an EQ of 16 are two very different things. Any chance you missed something like this?
    Incase you did, you could try loading the stock table as a comparison and going over each table to make sure the changes made are ones you really wanted to make.
    May 2006
    im having the same problems went through the tutorial tried to start the car died again died held the throttle all the way down got it started but it was comanding 1.1:1 AF so it would just die. Dont know yet trying to figure it out Put my original file back in car starts fine?
    As SSpdDmon said, watch your units, are you using AFR, EQ or Lambda...?
    Sounds alot like your units are EQ and you're setting the values as AFR, or vice-versa.
    May 2006
    I must have had my units messed up I wanted to use all AFR. I just started over and now its seems to be fine.
    mtnman i would just start over and leave it in EQ
  1. Stock truck idle problems after flash..?
    Last Post: August 28th, 2009, 09:07 AM
  2. Flash Scan V2 problems
    By loafycleetus in forum FlashScan V2
    Last Post: April 20th, 2009, 02:51 AM
  3. 2005 colorado I5 flash problems
    By nonnieselman in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: July 9th, 2008, 05:00 PM
  4. Flash problems
    By slowhawk in forum General (Petrol, Gas, Ethanol)
    Last Post: January 10th, 2007, 01:40 AM
  5. has anyone had vtd problems after bench flash of costom os
    By madprof01 in forum Custom Operating Systems
    Last Post: April 26th, 2006, 01:30 AM
