Hi,
I have a version of OS that I can't find in .ctz. There's a function to import LML file.. I read the CM2350 with my tool but 4M file doesn't fit
in the import function.. Is there a way ?
thanks,
Marc
Hi,
thanks,
Marc
Not sure what tool you used Marc but there is additional memory in the CM2350B that is not contained in the main CPU 4Mb flash, EFILive is expecting that data to be there which is why it is probably complaining about your file.
Im using my home made tool to read it. I also have access to 'other' memory parts.. but the problem is..
1- Is the Import function allow the importation of Cummins files ( MPC,epr,fls ) or only E86A ? It will fix me on the rest..
The MPC memory in the E86 is 2M, the one in the 2350B is 4M.. The import fonction want it to be 2M.
thanks,
Marc
The import function was only for E86A with binaries read from Alientech.
if you have a sec, pm me plz.
don't hold your breath on this, you won't get any answer. I even contact their tech support and the guy didn't know what i was talking about.. yeah right... all 2013+ .ctz file come
from outer space...
I'll find the way how to do that...
Post your bin files up here then, I'll take a look.
There is a secondary CPU in the CM2350B that is required to be flashed too, if your tool reads that out then I can tell you where everything needs to sit so the software will happily load your file. We aren't trying to stop anyone using the function, the LML import tool was a different situation.
This is from the MPC. I'll get back to you with the other one.
thanks,
Marc
This is a 4mb read. I get the above error when I try to open in V8.
Thanks,
2015 32370531CG 68RFE.zip
