Results 1 to 10 of 18
Thread: CM2350B import
    Nov 2016
    Default CM2350B import
    Hi,
    I have a version of OS that I can't find in .ctz. There's a function to import LML file.. I read the CM2350 with my tool but 4M file doesn't fit
    in the import function.. Is there a way ?
    thanks,
    Marc
    Not sure what tool you used Marc but there is additional memory in the CM2350B that is not contained in the main CPU 4Mb flash, EFILive is expecting that data to be there which is why it is probably complaining about your file.
    Nov 2016
    Im using my home made tool to read it. I also have access to 'other' memory parts.. but the problem is..
    1- Is the Import function allow the importation of Cummins files ( MPC,epr,fls ) or only E86A ? It will fix me on the rest..
    The MPC memory in the E86 is 2M, the one in the 2350B is 4M.. The import fonction want it to be 2M.
    thanks,
    Marc
    The import function was only for E86A with binaries read from Alientech.
    Nov 2016
    if you have a sec, pm me plz.
    Feb 2012
    Any way of getting around the complaining of file size, I get "file size does not match controller size". How do we extract the other data to make V8 happy then?
    Nov 2016
    don't hold your breath on this, you won't get any answer. I even contact their tech support and the guy didn't know what i was talking about.. yeah right... all 2013+ .ctz file come
    from outer space...
    I'll find the way how to do that...
    Post your bin files up here then, I'll take a look.
    There is a secondary CPU in the CM2350B that is required to be flashed too, if your tool reads that out then I can tell you where everything needs to sit so the software will happily load your file. We aren't trying to stop anyone using the function, the LML import tool was a different situation.
    Nov 2016
    This is from the MPC. I'll get back to you with the other one.
    thanks,
    Marc
    Feb 2012
    This is a 4mb read. I get the above error when I try to open in V8.
    Thanks,
    2015 32370531CG 68RFE.zip
  1. Possible to add Incal Import tool?
    By Mitco39 in forum Cummins 6.7L
    Last Post: November 26th, 2017, 01:03 PM
  2. CM2350B Run Modes
    By 30 RUM in forum Cummins 6.7L
    Last Post: November 22nd, 2016, 01:03 PM
  3. Cm2350b
    By catman3126 in forum Cummins 6.7L
    Last Post: January 14th, 2016, 03:50 AM
  4. Import data.
    By 5.7ute in forum General
    Last Post: September 20th, 2010, 11:54 AM
