Anyone deleted VATS on a 2016 E92 with EFI? I tried for several hours and it could never the injectors to fire, am assuming its VATS still.
Hi Lorenz,
Please post the stock tune file, I'd like to have a look.
Will be a starter motor relay issue still, I don't recall if it is in the E92 but on the 2010+ E38's there was a calibration '{G1220} Starter Relay Type' that needed to be changed as well.......or you can just put a relay on the starter motor output. The ECM just wants to see a load on there before it will allow injectors.
