Results 1 to 4 of 4
Thread: {B1602} Multiplier based on coolant temperature for airflow correction.
    Feb 2007
    Default {B1602} Multiplier based on coolant temperature for airflow correction.
    E40 PCM, can anyone confirm this calibrations function? {B1602} I'm guessing it modifies the minimum idle airflow table
    LABELS Airflow Correction Coolant Multiplier (Factor)
    ECT
    Last edited by Gelf VXR; January 4th, 2017 at 10:57 PM. Reason: added text that disappeared?
    Feb 2007
    Looks like {B0110} is baro and ect correction for main VE.
    Hi Gelf, please can you post your stock E40 tune file that I can look at.
    Feb 2007
    Hi Joe
    stock file attached.
  1. Fuel Temperature Density Correction
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2016, 09:23 PM
  2. Replies: 6
    Last Post: November 18th, 2014, 10:14 AM
  3. Coolant based fueling
    By Highlander in forum Gen III V8 Specific
    Last Post: July 20th, 2009, 07:16 AM
  4. V8 BBL Logging LBZ Engine Coolant Temperature Problem
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: May 24th, 2009, 09:22 AM
  5. coolant temperature
    By ws6togo in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:23 PM
