I have swapped a LQ9 into a 70 GTO using the 0411 computer. To retain the RAM AIR hood I opted to use a 4 barrel throttle body setup. I was initially going to fabricate a mount for a MAF and put it in the air cleaner, but i have simply started the car with a nearly stock tune and with few changes it runs and drives really well. Should I switch to a COS or what is the best was to run SD with the tune as is? Or I guess would it be worth it to fab up that MAF?
