Results 1 to 10 of 17
Thread: Does a speed density tune need a COS?
    Apr 2007
    Default Does a speed density tune need a COS?
    I have swapped a LQ9 into a 70 GTO using the 0411 computer. To retain the RAM AIR hood I opted to use a 4 barrel throttle body setup. I was initially going to fabricate a mount for a MAF and put it in the air cleaner, but i have simply started the car with a nearly stock tune and with few changes it runs and drives really well. Should I switch to a COS or what is the best was to run SD with the tune as is? Or I guess would it be worth it to fab up that MAF?
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Mar 2009
    Quote Originally Posted by zapp168 View Post
    I don't think a MAF would work to well in the air cleaner. It may easier to go to SD. And to use low and high octane spark tables with adaptive spark, you will need to run a COS. Running the tune as is would make it run on the low octane table all the time.
    00 Silverado Z71, LQ9 w/ LS3 heads, BTR cam, Whipple 2.9@8#, 4l80E
    MAF plumbing needs to be straight before/after the MAF.
    +1 what LastCall said...
    summarizing:
    - MAF-less, the GM OS's run from LO spark table.
    - MAF-less, the COS's run adaptive HO/LO spark
    Apr 2007
    summarizing:
    So the COS would still allow the HI/LO spark tables to function VS. copying and pasting the HI table to the low table. And for my own knowledge the large opening on the one side of the MAF into the air cleaner housing would make it inaccurate? I honestly was not crazy about making it work anyway....LOL.
    I believe it was CO3? Correct?
    Thanks for the replies!
    Yes, COS allows adaptive spark to continue functioning when a MAF DTC is present (which is needed for failing the MAF for running SD).
    MAF sensor needs straight and uniform air flow... i.e. nearby bends in the ducting cause the air flow to bunch up on the outside of the bends.
    Yes COS3.
    What GM OS id do you have...?
    Apr 2007
    Yes COS3.
    That was actually going to be my next question. I am currently running 12202088, in the past no matter what I always changed to 12212156 figuring it was a later system thus better. Is it worth while to change to 12212156 then go to the COS?
    Yes and no, depending on your plans...
    12212156 is a year later (I'm told GM fixed some things compared to 12202088)...
    but it also has COS5 available (if you ever need alpha-N), 4L80E variants (trans segment), and Express Van variants (fuel system segment).
    Apr 2007
    Ya.....Might as well!
    Thanks for your help!
    Copy your 12202088 tables to 12212156 (take your time, go thru each table), and then full flash in 12212156 and make sure it runs at least as good as 12202088 did.
    If it does not, go back thru the tables to see what's different.
    Shortcut: F-car 12212156 runs exactly the same as F-car 12202088 without any edits.
    Apr 2007
    It was the stock 2001 tune with the security turned off...... So I can't imagine the stock 2002 12212156 tune with the security turned off (maybe just check the IFR) shouldn't run the same if not better.
  1. TP limited at idle on e38 speed density tune
    By dieselmd in forum E37, E38 & E67 PFI ECM's
    Last Post: June 13th, 2014, 12:54 PM
  2. Replies: 7
    Last Post: November 1st, 2010, 08:24 PM
  3. Need Help with Speed Density tune!
    By ls698ta in forum Gen III V8 Specific
    Last Post: May 10th, 2010, 12:48 PM
  4. Do I need the Speed Density COS?
    By MisterGuru in forum Custom Operating Systems
    Last Post: June 4th, 2009, 11:41 AM
  5. C6 Zo6 TT 2 bar Speed Density Tune
    By dgdyno in forum E37, E38 & E67 PFI ECM's
    Last Post: November 19th, 2008, 02:02 PM
