Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Does a speed density tune need a COS?
    Mar 2009
    Do you have an automatic trans? Electronically controlled? Reason I ask is because pre-411 swap I ran a VE tuned blackbox. I don't recall if I ran the 411 MAFless but I don't see why I would have. I do recall that being MAFless caused the trans line pressures to max out. I'm not sure if a COS would fix this or not. With the Transgo in the 4L60 I ended up cracking the case where the servo sits. It wasn't until well after the 4L80 swap that I plugged it back in. I think I plugged it back in right after the 411 swap because it was shifting so harshly no matter what settings I changed. I went so far as to double the factory torque reduction on upshifts and it did nothing. So I plugged it in and forgot about it. The next day on my way home from work the truck was shifting much more smoothly so I went into the tune and altered shift times to my liking and the truck took to it. I'm glad I plugged it back in, sure would have sucked to frag another trans.
    Mar 2009
    Default Does a speed density tune need a COS?
    That can happen running speed density. There is a note in the AutoVe tutorial. I've pasted it below, you may want to check it out.
    Vehicles equipped with automatic transmissions should go to table {E0104} Transmission DTC Fault Pressure Modifiers and set P0101, P0102, and P0103 to NO to prevent the PCM from increasing shift pressures.
    Yes, set those to No...
    and make sure the VE table does NOT under-report airmass.
    Apr 2007
    Did not check those tables, but the car is running and shifting perfect, I actually lowered the voltage on the force motor to firm up the shift a little.
    98 WS6, M6, 02 PCM, CO3, SD 2 Bar tune, 416 D1SC Procharger, 73# Injectors, Patriot Lq9 heads, 232 int 240 exh. Lift .595 int .608 exh 115.. header, Intake, AEM WB.
    Junior Member rich24v's Avatar
    Jun 2011
    MAF plumbing needs to be straight before/after the MAF.
    +1 what LastCall said...
    summarizing:
    - MAF-less, the GM OS's run from LO spark table.
    - MAF-less, the COS's run adaptive HO/LO spark
    Does this also apply to MAF-less E38 ?
    UK spec 2009 HSV VXR8 6.2 LS3, E38, HeartBeat Supercharger running ~9psi,1 7/8" long tubes, cat back exhaust.
    Upgraded cam and springs of unknown specification, all I know is, it's a small cam with no overlap, suits the s/c.
    ATI damper, LS9 twin plate clutch, 548rwhp. twin PLX widebands to twin gauges.
    Currently running dismal HPTuners....NOW DUMPED !, Completed migration to EFIlive and slowly mapping it in.
    628rwhp.....with a lot of tuner help
    Quote Originally Posted by rich24v View Post
    MAF-less E38 runs from LO table (i.e. in presence of MAF DTC).
    ~Moderator~
    Apr 2007
    Quote Originally Posted by zapp168 View Post
    They were already set to "no"
  1. TP limited at idle on e38 speed density tune
    By dieselmd in forum E37, E38 & E67 PFI ECM's
    Last Post: June 13th, 2014, 12:54 PM
  2. Replies: 7
    Last Post: November 1st, 2010, 08:24 PM
  3. Need Help with Speed Density tune!
    By ls698ta in forum Gen III V8 Specific
    Last Post: May 10th, 2010, 12:48 PM
  4. Do I need the Speed Density COS?
    By MisterGuru in forum Custom Operating Systems
    Last Post: June 4th, 2009, 11:41 AM
  5. C6 Zo6 TT 2 bar Speed Density Tune
    By dgdyno in forum E37, E38 & E67 PFI ECM's
    Last Post: November 19th, 2008, 02:02 PM
