I'd like to know ( before testing it ) if CAX file allow to modify data in the OS segment ?
thanks,
Marc
thanks,
Marc
Potentially yes because of the way the Cummins ECM's are designed........you do understand the risks though right? Cummins ECM's can be bricked just by changing calibrations the wrong way, changing code the wrong way could be just as tragic.
Yes, I do understand
thanks,
Marc
You can romboot the ecm if it is bricked via bench harness!
how exactly are you guys creating cax files?
It all started a long time ago
Rev it up, Drop the clutch, See what happens?
From another thread
Base on this thread, the CAX files is just a simple text file. It's finding the data you need to create it that will be the challenge.
Duane
2008 Ram 3500 QuadCab
Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
