Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: Need to verify if tune file I downloaded is 4L80E
  1. #11
    Here is 4th gear ratio reference: 11506-4l80e-question
  2. #12
    i.e. to see if 4th gear is commanding you should see engine rpm drop even tho the pid GM.TIS stays the same as for 3rd gear...
    take a log of these pids:
    - GM.TIS
    - GM.TOS
    - SAE.RPM
    - SAE.VSS
    - SAE.TP
    - SAE. MAP
    - GM.GEAR
    - GM.BOXRATIO
    - GM.TCCMODE
  3. #13
    May 2014
    - GM.TIS
    - GM.TOS
    - SAE.RPM
    - SAE.VSS
    - SAE.TP
    - SAE. MAP
    - GM.GEAR
    - GM.BOXRATIO
    - GM.TCCMODE
    Thanks I will get to it in a few days. I just had dental surgery today and am out on painkillers for some time .. lol
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  4. #14
    May 2014
    Do you also have the TCM wiring diagram that goes with that, I want to see if they agree.
    Yes the connector schematic I obtained while trouble shooting was the correct one for the tune and shows 4L80E and 4L60E options on the G3500 van T42 TCM. Everything else seems to be in the same spot as in the T42 Connector on the sloppy mechanics page. I'll verify again on GM site to make sure and convert them to images instead of PDF so I can upload on EFILive
  5. #15
    Quote Originally Posted by Mean Green Z28 View Post
    No worries, take your time, take care.
  6. #16
    May 2014
    Well the main difference I see for now is that the 2009 T42 Connector has 3 sets of the GMLAN Serial Bus signals coming to it while the older Connector shows only 2 sets. Would that cause any issues? the Circuit number for them all is 2500/2501 ... the only other changes are the TFP Switches (A,B,C) and where the ISS Low signal is terminated (26 vs. 45).
    If I was to add the two GMLAN signals to 15 and 19, can I just jump it off of the other pins or is there a chance that these area headed somewhere else? Ofcourse I have to verify with my year's connector be I say this is it. Haven't got access to the site yet.
  7. #17
    May 2014
    Here we are!!! Everything converted to JPG so I can upload them
    2009 G3500 Transmission Connector
Name:	2009 G3500 VAN Transmission Connector Pinout.jpg
    2009 G3500 T42 Connector
Name:	2009 G3500 VAN T42 Connector Pinout.jpg
    2009 Silverado Transmission Connector
Name:	2009 Silverado 4L60E Transmission Connector Pinout.jpg
    2009 Silverado T42 Connector
Name:	2009 Silverado T42 Connector Pinouts.jpg
    Here's an easier pic with comparisons of each connector...
    2009 G3500 vs. Silverado T42 Connector Comparison
Name:	2009 G3500 vs. Silverado T42 Connector Comparison.jpg
    2009 G3500 vs. Silverado Transmission Connector Comparison
Name:	2009 G3500 vs. Silverado Transmission Connector Comparison.jpg
  8. #18
  9. #19
    May 2014
    So I opened up the scanner tool and started saving up a pid file ... most are invalid?
  10. #20
    Thanks for posting above pdf's.
    In scantool go Info->Validate Pids
    ( unless T42 does not support those pids, which does not help at all )
  1. Replies: 4
    Last Post: March 4th, 2016, 03:32 PM
  2. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  3. Looking for a T42 4L80e cal file
    By wwaveforms in forum Gen IV V8 Specific
    Last Post: March 10th, 2013, 04:32 PM
  4. Can't get stock tune downloaded on laptop
    By Devil_Z in forum Duramax LLY
    Last Post: June 2nd, 2010, 05:12 PM
  5. Need a tune file for O/S 01270003 with a 4L80E
    By thunder550 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 25th, 2007, 04:10 PM
