Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: Need to verify if tune file I downloaded is 4L80E
  1. #31
    Lifetime Member BLK02WS6's Avatar
    Jun 2005
    Joe,
    Does the TCCMODE in that log make sense to you? It has puzzled me since the first log he sent me. It seems to randomly show "Slew", "Rel", "App", "Lock" and even "unknown". Doesn't correlate to changing TPS/MPH... I don't know enough about what should be seen for some of these parameters.
    GM EFI Tuner
    02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
  2. #32
    Jun 2005
    Actually, it seems to be unlocking after shifting from 3rd to 4th and immediately locking back up again. Should it unlock after the shift or stay locked through the shifts?
    GM EFI Tuner
  3. #33
    Quote Originally Posted by BLK02WS6 View Post
    You can change whether the TCC stays locked during a shift or not via programming.
  4. #34
    Jun 2005
    I know in some cases you can with the toggle that allows it, but this OS doesn't have the toggle - and based on the TPS/MPH, it should have stayed locked. I don't see why it is dropping in and out based on the settings.
    GM EFI Tuner
  5. #35
    May 2014
    Well guys ... stock converter was just put in ... Ran a pressure guage and per recommendation by trans builder, set line pressures to be in the 80-125 range (before swapping to stock)
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  6. #36
    Jun 2005
    Are all problems resolved now that the stock is back in?
    GM EFI Tuner
  7. #37
    May 2014
    Driving home in a bit
  8. #38
    May 2014
    Well I think we eliminated the weakest link! Goes through shifts nice and firm and locks up nice and tight! However, I don't have the cable to log cos I had to give it back and same with the mechanical gauge I had to return to the trans shop. I will invest in a trans pressure gauge soon.
    Have to go over the tunes now and see if there's anything I wanna put back to the way it was before we started troubleshooting this ... like PWM control and shift pressures ect.
    We did notice a lot of misfires during a "spirited acceleration" towards the top end/shift points; which Jason said may have attributed to the flashing engine light (didn't turn on this time), but also felt it may be because of the cam ... did you see any when tuning?
  9. #39
    Jun 2005
    Make sure you leave all of the scaling stuff I did. I would keep most of the changes actually...
    Time to get the new converter
    GM EFI Tuner
  10. #40
    Quote Originally Posted by Mean Green Z28 View Post
    Here it is with MIN tables maxed out .. you can see the TCC slip on the RPM.
    I also logged a run with force motor current and it runs at about 0.6A but gets to about 0.5 as I roll into it ... is that too low?
    Your log shows light TP, so 0.5A is ok;
    the lower the Force Motor Current (PCS solenoid current), the greater the line pressure... (compare the pids TFMPRS and TFMCUR).
    Also log GM.TCCSLIP, GM.SHIFTLAST, GM.SHIFTERR.
    Joe,
    When TP is steady, TCCMODE should go to AppEn and either App or Lock.
    The log shows TCCMODE to Slew and then to Unknown, weird... stays in Slew for 7 seconds before going to Unknown.
    I can see by comparing RPM to TIS that the TCC is unlocked during Slew and is locked during Unknown.
  1. Replies: 4
    Last Post: March 4th, 2016, 03:32 PM
  2. Need blackbox 4L80E tune for my 4L80E segment swap
    By Supercharged111 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: September 10th, 2013, 10:57 AM
  3. Looking for a T42 4L80e cal file
    By wwaveforms in forum Gen IV V8 Specific
    Last Post: March 10th, 2013, 04:32 PM
  4. Can't get stock tune downloaded on laptop
    By Devil_Z in forum Duramax LLY
    Last Post: June 2nd, 2010, 05:12 PM
  5. Need a tune file for O/S 01270003 with a 4L80E
    By thunder550 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 25th, 2007, 04:10 PM
