Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: 2011 lml. Looking to delete.
    Jan 2017
    Default 2011 lml. Looking to delete.
    Got my flashscan v2 early and im playing with the software. Need help on how to read the computer and tune truck to run on deletes. Help would be much appreciated
    Sent from my SM-G920W8 using Tapatalk
    You can't read the ECM, you can't do deletes on the LML.....were you told that before you bought it?
    Jan 2017
    O won a 6.7 cumminns thats already deleted but imbswitching to efi live. My dd has the lml and wants it deleted also. So i bought a flashscan. My question is why can you buy efi live dpf delete tunes from a vendor, but cant access anything from the laptop? Do you have to download the stock file from another source?
    Dec 2013
    If you see a delete tune offered by an EFI vendor then that vendor has modified the tune outside of EFI live prior to tuning with EFI software and license/sell it to customers. That is a quick overview of what is going on.
    That being said you can use a V2 or autocal to tune both 6.7 cummins and LML but tune files will need to be purchased accordingly from vendor.
    Mar 2009
    We do not have access to the delete tables in the US, but they are available outside the US(due to the EPA). Some tuners offer delete tunes that they have built, and simply use EFILIVE as a flashing tool to flash the tunes in that they have built.
    Jan 2017
    Not sure about you guys, but if we are talking about the LML, then yes, you can do an EGR Delete with EFI Live. We do work for off road racing, and that is the one thing that goes right away. I know you can't see the parameters in the US Version of EFI Live, and I do know you can't mess with the EGR down there. But I don't live there, so ya.
    Feb 2017
    so if your outside the US you get access to the delete tables??? If so... thats kinda jacked up that my money doesnt buy the same thing someone else's does based on where they live. If other versions of the software are available what decides what version you get?
    Senior Member DieselMafialb7's Avatar
    May 2012
    Quote Originally Posted by izazzel View Post
    Message me your trucks info I can get you a blank file with codes killed
    US Law, EPA enforcement, little things like that
    Feb 2017
    no i mean what tells the software/hardware that you live in the usa
  1. 2011 lml OS6249 delete issues
    By LMMPerrona in forum Duramax 2011+ LML / LGH
    Last Post: July 29th, 2021, 08:12 AM
  2. 2015 LML Delete
    By Road in forum Duramax 2011+ LML / LGH
    Last Post: June 1st, 2018, 02:56 AM
  3. lml delete
    By akaponch in forum Duramax 2011+ LML / LGH
    Last Post: June 30th, 2017, 05:10 AM
  4. 2011 6.7 delete problems, non US customer
    By Vlad0380 in forum Cummins 6.7L
    Last Post: November 8th, 2016, 11:00 AM
  5. 2013 lml delete question
    By outlaw83 in forum Duramax 2011+ LML / LGH
    Last Post: July 7th, 2016, 10:12 AM
