Results 21 to 30 of 34
Thread: 2011 lml. Looking to delete.
  1. #21
    Oct 2010
    Yep, an EPA thing. Was hoping our new president could drain the EPA swamp, but it seems they have more power than the president. I should have kept my old duramax. I didn't know my EFILive would be pretty useless for my new truck. When you cannot delete the DPF and then when you change tune files you can mess up emission sensors and get CEL easily. You will likely burn more fuel because of regeneration more often. EFILive was great for the old Duramax. Well, there is one thing I can still do, and that is to raise the speed limiter limit speed to beyond what the truck can do.
  2. #22
    Oct 2010
    You advertise "banks 4" monster exhaust-turbo back". Pretty obvious an important piece or two is missing from your emission system. That might be frowned upon. Maybe you mean turbo-back to CAT and DPF. You say, "egr delete plate". There's that frowned upon word again. Of course, you used the singular version and not plural, so that's probably acceptable.
  3. #23
    Sep 2015
    I’ve been trying to accomplish this for a while. Already have my IP address changed for Netflix etc... I’ve removed V8 and V7.5 and downloaded again and still don’t have the extra tables. Anything else I should try? Thanks.
  4. #24
    RDLLC, I don't know where you got the idea that EFILive does some sort of location checking via the internet when it runs because it doesn't, the calibrations are gone, that is why you don't see them.
  5. #25
    Aug 2019
    Quote Originally Posted by DieselMafialb7 View Post
    Message me your trucks info I can get you a blank file with codes killed
    Need dpf delete, can you do it?
    Enviado desde mi Moto Z (2) mediante Tapatalk
  6. #26
    Sep 2015
    Just always see people say “it’s not supported in the US”, so just figured something was different in another country.
  7. #27
    Oct 2012
    Quote Originally Posted by RDLLC View Post
    You don't have enough posts for a PM. Check your profile wall.
  8. #28
    Nov 2019
    DieselMafialb7, can I give you my trucks info? I'm not sure how to, if I'm allowed yet, to PM you
  9. #29
    Mar 2020
    Could I get that file? I’m having the same issue
  10. #30
    Mar 2022
    Dieselmafialb7, can you PM me, please?
  1. 2011 lml OS6249 delete issues
    By LMMPerrona in forum Duramax 2011+ LML / LGH
    Last Post: July 29th, 2021, 08:12 AM
  2. 2015 LML Delete
    By Road in forum Duramax 2011+ LML / LGH
    Last Post: June 1st, 2018, 02:56 AM
  3. lml delete
    By akaponch in forum Duramax 2011+ LML / LGH
    Last Post: June 30th, 2017, 05:10 AM
  4. 2011 6.7 delete problems, non US customer
    By Vlad0380 in forum Cummins 6.7L
    Last Post: November 8th, 2016, 11:00 AM
  5. 2013 lml delete question
    By outlaw83 in forum Duramax 2011+ LML / LGH
    Last Post: July 7th, 2016, 10:12 AM
