To give a quick background on whats going on. I have a 09 Saturn sky that I have put a LS in. I used a e67/T42 and I now have everything working including trans but no speedo. All the modules are communicating. Theft works as well as all the gauges except speedo. On the scanner it show vss and replicated vss signal. The tcm is obviously seeing signal because it is replicating it and trans is shifting. The cluster receives all the info via can. I can not see what the cluster is actually seeing even with my tech2. I even tried a new tcm just incase. Does anyone here have a tune file for a stock 09? I would like to look at the org settings. Someone with sticky fingers needed my laptop I had the org files on so it is gone. That was one of the files that I had not backed up yet. I attached a scan of car show speed info . Thankssky new tcm.efi
