Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 91 to 100 of 116
Thread: 454 411 Swap
  1. #91
    Lifetime Member SS2win's Avatar
    Feb 2005
    It's under "System|Vehicle Platform". After I flashed the system segment, getting the vortec to run was as easy as making the options match the vortec low res tune.
    2001 Camaro SS
    EFILive Custom OS3
  2. #92
    Mar 2009
    Quote Originally Posted by SS2win View Post
    What software version do you have? All I see is theft, low coolant, AC, fans, tach.
  3. #93
    Feb 2005
    I run the latest
    2001 Camaro SS
    EFILive Custom OS3
  4. #94
    Mar 2009
    What all is in it? I have theft, low coolant, AC, fans, tach. For some reason fuel system, system, and speedometer won't open on COS5 for my 1500. I have a newer .calz file for COS5 than I do the dually's OS which got me the transient fueling tables I'd been missing out on.
  5. #95
    Feb 2005
    You're missing quite a bit. Maybe they won't open because cos5 borrows from those areas of the bin to provide expanded features? If I get some lazy time I'll try upgrading to see if anything changes or if I continue to have the same options.
    2001 Camaro SS
    EFILive Custom OS3
  6. #96
    Mar 2009
    Something's weird for sure because I've been in there before to tweak stuff like the speedo for gears and tires. This was with the V2 plugged into the laptop but not the vehicle.
  7. #97
    Feb 2005
    Why are you running COS?
    2001 Camaro SS
    EFILive Custom OS3
  8. #98
    Mar 2009
    To read boost, but here in CO I barely crack 100kpa with the puny 1.6L Whipple on the 1500. I have a 2.3 getting rebuilt for the dually, so same need for COS there.
  9. #99
    Feb 2005
    Oh yeah I guess I could have figured that out from your Sig. It might be a good time to start over and upgrade the OS see if things work for you.
    2001 Camaro SS
    EFILive Custom OS3
  10. #100
    Feb 2005
    Well thanks to Hurricane Michael, I found the free time to try COS3 and COS5 on my L29/454 Vortec 0411 swap... While I haven't done extensive testing I can say that both seem to work well and 4LO shifts fine.
    2001 Camaro SS
    EFILive Custom OS3
  1. 0411 swap on 99 Vortec 454
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 22nd, 2013, 12:49 PM
  2. Vortec 454 swap
    By blazinblue in forum Vortec V6/V8 Specific
    Last Post: April 16th, 2012, 03:23 PM
  3. 411 swap did not go well
    By FeetDry in forum Gen III V8 Specific
    Last Post: June 9th, 2011, 04:50 AM
  4. 411 swap cmp -40*
    By 9851Chevy in forum Vortec V6/V8 Specific
    Last Post: February 7th, 2011, 07:35 AM
  5. 2.2L s-10 411 swap?
    By haulinit in forum General (Petrol, Gas, Ethanol)
    Last Post: August 5th, 2009, 06:03 AM
