I'm on 7.5.5 build 72. All I tune is my old garbage so no need for me to update. I was gonna ask how the hell to see what the idle wants but it looks like a peek at B4108 is going to tell me. If idle STFT is disabled, why does there appear to be LTFT active in that same RPM? Or does it just use the STFTs to influence LTFTs at idle when disabled without applying them? I'm used to a rich condition causing a fart smell to come out of the exhaust but judging by the O2s low voltage it seems a lean condition may do the same? I'm more familiar with what rich vs lean smells like on non-catted exhaust systems. A quick view of my most recent cruise logs are showing LTFTs in the 7-9 range so I'm thinking a quick easy 10% VE bump ought to help, no? I'm torn between making this run correctly on as stock of a tune as possible vs just hooking up the wideband and doing a calc.vet to cover something else up that I might be missing by using a small block PCM to run a big block. Like whatever is not allowing all my low load timing through, I think there are like 6 or 8 pids to log for that.
