Quote Originally Posted by tune time View Post
Thank you for helping. the AFM 1000 is as follows
0.0 volts=8.0 afr =.55 lambda
5.0 volts=18.0 afr =1.24 lambda
14.56 is lambda 1
math is lambda1 is volts x 2+8
The calc_pids.txt file posted above is based on these values.
( 14.56 and 14.57 are different by less than 0.07% i.e. they are the same )
