When only wanting 2 of the 4 running, and attempting to modify and existing chart, there is no NONE.
Could that be added?
Two possible solutions. Make a new chart and only set up 2 items or set the color of the one you don't want to see to black. New charts come with nothing set so you can leave them blank.
Ira
Yah figured that one out, but kind of a pain if you want to quickly unselect something so you can unclutter a chart.
Ugly way I figured out was to select a calc pid, add it to the chart, then remove the calc pid, the chart then shows the pid striked out and effectively cleans it up.
Most likely now that I think about it, making a NONE pid is the way to fix that.
DID IT!!
Add to: 915 or whatever number above what you have
Calculated
*CLC-00-915
% 0.00 0.0 .0 "0"
Add To : Just chose any section just to get it in and f5ff to put it at the very end
# Calculated PIDs
CALC.BLANK F5FF CLC-00-915 % Fuel "Empty PID"
Save your sae_generic.txt and reload EFILive
Load your LOG, add this calc'ed PID in and then change the charts as needed now having a BLANK one if you just wanted to clean or quickly not have something in a chart on the fly without making a whole new one.
Or just right click on the chart series' caption and select "Remove <xxx>" where <xxx> is the chart series' caption.
:oops:
DOH!!!
Guess that will work too
So obvious when he points it out, so hidden when he doesn't!
Ira
