Results 11 to 20 of 23
Thread: Known Issues With Current Public Release
  1. #11
    May 2013
    I have V7.5 320 and V8 2.4.314 and have updated my firmware
  2. #12
    May 2013
    I installed V7.5.7 Build 309 and V8 2.4.314 and an old suitable tune and tapshift works again. Magic, I just cant ever update EFIlive again
  3. #13
    May 2013
    Since loading older V7.5 309 both D9601 an D9605 have disappeared from the V7.5 build 320 so I have opened the problem file and cant find D9601 an D9605 anywhere... Confusing but problem solved. Thanks for your response Cindy. Im using Built 320 again
  4. #14
    Lifetime Member izaks's Avatar
    Aug 2003
    "Setting D9602 to ENABLED, disables SPORT SHIFT mode when trans lever is moved to the SPORT position. If you then go into manual mode, it is locked in this mode, even if trans lever is moved back to auto. You have to shift out of drive and then back in to drive to disable manual mode and revert to normal drive mode. Tested on 2011 and 2012 VE."
    Came in with the previous public release
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
  5. #15
    Feb 2006
    Negative timing (ATDC) doesn't show up on the V2 screen when logging the E98 controller. It got broken about 2 updates ago. I.e it's missing the - mark. (at least im pretty sure it used to)
  6. #16
    Nov 2005
    Quote Originally Posted by 6ltrtorana View Post
    If you can please provide your OS # the developer can take a look. Build 309 was prior to the calz update in August 2016, build 320 after, so it's plausible.
    Cheers
    Cindy
  7. #17
    Nov 2005
    I've re-read your post. You won't find D9601 and D9605 in V7.5.309. They were added in after that version.
    Your tap-shift tune file will continue to work in both old and new software. You will need to review the other changes you made to the tune file in V7.5.320 that may have caused that to stop working.
    Cheers
    Cindy
  8. #18
    Nov 2005
    Quote Originally Posted by izaks View Post
    Tap shift works from the factory on VE via the BCM.
    D9601 thru D9605 were added in August 2016 to try and help people doing conversions and wanting to get tap shift working from a wired switch.
    Cheers
    Cindy
  9. #19
    Nov 2005
    Quote Originally Posted by Tre-Cool View Post
    Doesn't show up? or showing the wrong values? What version do you believe it was displaying correctly in?
    Cheers
    Cindy
  10. #20
    Nov 2005
    Updated software is now available. Known issues should be posted in this thread https://forum.efilive.com/showthread...Public-Release
    Cheers
    Cindy
  1. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 12:02 PM
  2. Known issues with Aug 07, 2015 Public Pre-Release
    Last Post: August 8th, 2015, 11:42 AM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
