Results 1 to 3 of 3
Thread: Cam is in now what?
    May 2006
    Default Cam is in now what?
    Hi guys. Kinda new here, so here goes. Installed the MS3 cam. Ls6 intake. underdrive pullys ect. Car idels at 900 right now no tunning done at all. I am going to do the Auto Ve, and bump up the idel to around 1100 or so. What else should i check out. My wideband will njot be here untill next wednesday.
    thx
    Lifetime Member Doc's Avatar
    Oct 2005
    Why do you want to increase the idle to 1100rpm? Is there a problem with the 900?
    www.efialchemy.com
    www.greatamericancarwar.com
    Oct 2005
    Do you tune idle if you like. Do a search for idle tuning. Closed loop should make part throttle action ok, but with a cam you usually need to tune idle and transitions with cracker and follower. You can start these without needing a wideband immediately.
    2014 VF SV LS3 Maloo.
