Results 1 to 10 of 19
Thread: Holden Crazy
    Default Holden Crazy
    what happened to holden crazy file site?
    Mark
    No longer available. You can go here to get tune file's.
    https://www.dropbox.com/sh/4ydh5wltk...s4SRJ9NGa?dl=0
    These's files are hosted by me.
    330 rwkw EFILIVE OS 01290005 SD Cam / Head Tuned 6 speed VY SS Commodore
    10/71 Blown 572 Big Block Chev HQ 2 Door Monaro
    GM Performance Centre
    Busselton WA
    AUSTRALIA
    Phone: 0447 003050
    Jan 2009
    Bless you my friend!!!!
    Quote Originally Posted by johndaison View Post
    Will that file available? If yes, when?
    Use the DropBox link posted above, HoldenCrazy is defunct.
    Aug 2006
    hi does anybody have a std holden vf lsa e67 tune file os 12656942
    Nov 2018
    hi all im new to all this just queries if the efi v2 will also tune and read 5L (304 or 308) other than LS motors...
    No EFILive won't mitchy94, I'm not sure what software is around these days for those but back when they were king of the hill Kalmaker was the go to tuning deal. That was many years ago so there is probably something newer now.
    One thing though, those Holden ECM's for the local motor used a Memcal (aka chip) which was something you had to pull out of the ECM to retune it, there was no read/flash via a diagnostics connector on them.
    Lifetime Member limited cv8r's Avatar
    May 2005
    Kalmaker is still around and is alot cheaper than what it used to be, with a modified ECU you can tune in real time. Another place to look is here https://pcmhacking.net/forums/ , depending on what model vehicle you want to tune , also http://www.tunercat.com/ . You will need a UV eraser and chip burner, unless you modify your chip to take a flash chip.
    It's all good until it goes "Bang"
    New Member rucxy's Avatar
    Feb 2014
    If anyone is interested i can post up my original factory ECU E38 and 6l80e T43 tune files for an 06 VE Commodore (L98) SS-V.
    ECU OS 12612381 Rev AA last programmed by GM Aug 11, 2006
    TCM OS 24239353 Rev AA last programmed by GM Aug 11, 2006
    Quote Originally Posted by rucxy View Post
    Post them here, they may help someone.
  1. What happened to all the modified tune files holden crazy?
    By mvvette97 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 15th, 2016, 02:18 AM
  2. Why there are no updated files in holden crazy ?
    By wesam in forum Gen IV V8 Specific
    Last Post: September 27th, 2012, 01:55 PM
  3. Holden Crazy
    By Chevy366 in forum Lounge
    Last Post: November 17th, 2011, 07:35 AM
  4. Holden Crazy Tune File Repository
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: January 12th, 2006, 08:44 AM
  5. This is crazy!!
    By wait4me in forum Lounge
    Last Post: December 26th, 2005, 06:26 PM
