Try swapping rx with tx.
rx/tx needs signal ground connected also.
I'm checking with AEM to see if they are using the newer firmware that does not have the serial code in it, to save space.
my patch cable is for use with the alm widebands. so all i do is just put the blue wire from the aem into the rx pin for the v2 and it works. except for the latest aem firmware gauges where they don't appear to be transmitting at all.
Today I wired up for analog voltages, I've given up on serial since I can't get it to work at all. It's been cold here in Iowa and working in an unheated garage isn't fun, finally getting around to working on this. I have the analog voltages working with BBX and I've modified the calc_pids.txt file for the correct equation for my sensor but can't figure out how to get the 0-5v signal to show up as my lambda/afr. I can't find the right PID.
calc_pids.txt
LS1B_0681.efi
03 Silverado 5.3 ECSB 4x4 Z71
Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
2010 Tahoe VVT AFM 5.3
Stock for now
Use these:
*CLC-00-119
factor 0.5 1.5 .3 "{CALC.AEM_AD3}/{GM.AFR}"
*CLC-00-120
factor 0.5 1.5 .3 "{CALC.AEM_AD4}/{GM.AFR}"
*CLC-00-2058
V 0.0 5.0 .1 "{EXT.AD3}"
AFR 10.0 20.0 .2 "{EXT.AD3}*2.3750+7.3125"
lambda 0.5 1.5 .3 "(0.1621*{EXT.AD3})+0.4990"
*CLC-00-2059
V 0.0 5.0 .1 "{EXT.AD4}"
AFR 10.0 20.0 .2 "{EXT.AD4}*2.3750+7.3125"
lambda 0.5 1.5 .3 "(0.1621*{EXT.AD4})+0.4990"
*CLC-00-2060
factor 0.5 1.5 .3 "({CALC.AEM_AD4}/14.7)*{SAE.LAMBDA}"
CALC.AFR-WO2BEN.AD3 F110 CLC-00-119 factor "W02-Ben" "AFR BEN AD3 AEM"
CALC.AFR-WO2BEN.AD4 F110 CLC-00-120 factor "W02-Ben" "AFR BEN AD4 AEM"
CALC.AEM_AD3 F001 CLC-00-2058 "AFR,lambda,V" WO2-Analog "Wide Band AEM AD3"
CALC.AEM_AD4 F001 CLC-00-2059 "AFR,lambda,V" WO2-Analog "Wide Band AEM AD4"
CALC.BEN.AEMAD4 F110 CLC-00-2060 factor "W02-Ben" "AD4 AEM BEN from Lambda"
The ben's are for LS1 & E38.
Could I please get some help with syntax,
Why does this work:
V 0.0 5.0 .3 "{EXT.AD1}"
AFR 10.0 20.0 .3 "{EXT.AD1}*2.3750+7.3125"
LAM 0.5 1.5 .3 "(0.1621*{EXT.AD1})+0.4990"
EQR 0.5 1.5 .3 "1/((0.1621*{EXT.AD1})+0.4990)"
But this won't work:
LAM 0.5 1.5 .3 "{CALC.AEM.AFR}/14.7"
EQR 0.5 1.5 .3 "1/CALC.AEM.LAM"
CALC.AFR-WO2BEN.AD1 F110 CLC-00-119 factor "W02-Ben" "AFR BEN AEM"
CALC.AEM F001 CLC-00-2058 "V,AFR,LAM,EQR" WO2-Analog "Wide Band AEM"
CALC.BEN.AEMAD1 F110 CLC-00-2060 factor "W02-Ben" "AEM BEN from Lambda"
Stock for now
