Results 1 to 5 of 5
Thread: Calc pid to display previous frame value (delay data)
    Feb 2007
    Default Calc pid to display previous frame value (delay data)
    As title, is it possible to create a calc pid to display previous frame value, I'm sure ive seen this somewhere?
    For example, delay the MAF 1/10th of a second as it seems to respond quicker than the MAFSD
    Yes... in the V7 user manual pdf, look at the calc pids section, in the functions table look at the function FRAME.
    ~Moderator~
    Feb 2007
    Hi Joe
    I think this is the one I want, I want to return the value of an earlier or later frame, not the frame number, do you have an example of this pid?
    value() Syntax: value({PID},frame) Arguments: {PID}: a PID name. frame (optional): an expression. Return value: The specified PID’s value for the specified frame. If the frame number is not specified the current frame number is used. If the frame number is less than 0 then frame 0 is used. If the frame number is greater than the last frame, then the last frame is used.
    Aug 2013
    You can't 'shift' the actual MAF readings. You create a PID which becomes a new parameter and you then do the shift in that calculated parameter... the original MAF readings remain intact.
    I don't see any value in shifting the MAF readings... they are what they are and that's what the PCM is seeing and using to do its fueling calculations.
    I have done a shift for wideband readings in the past (I now use spreadsheets for all my tuning so I no longer use this scanner function). I'll put up a couple of pics to show you how I shifted the wideband readings and you can use that as an example of how to do a frame shift.
    This calc.PID was set to a 5 frame offset for the wideband as the vehicle I was tuning at the time had gutted cats and the WB sensor mounted in the rear O2 sensor bung... huge delay in wideband readings. I also divided by lambda to auto-correct for PE fueling situations (optional way of doing things, but worked for me).
    Feb 2007
    That's what I'm looking for, I think we are on the same page, I always see MAFSD lag just behind MAF, as you note the WB has a further delay in reading, I want to experiment with delay to the MAF and MAFSD a few frames to apply the fuelling correction.
  1. When did Freeze Frame data occur?
    By mys10v8 in forum General
    Last Post: August 13th, 2015, 12:20 PM
  2. Freeze Frame Data not available for E40?
    By DrkPhx in forum General
    Last Post: October 27th, 2010, 02:05 PM
  3. Freeze frame data
    By FeetDry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2010, 02:13 PM
  4. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  5. BBL data display/record decimal places
    By Kevin Doe in forum FlashScan V2 BB Logging
    Last Post: March 27th, 2008, 03:46 PM
