Results 1 to 10 of 11
Thread: recovering crashed pcm
    Jan 2006
    Default recovering crashed pcm
    Can I do a full flash on a pcm that was crashed with a handheld? I have a customer who just called with a 2003 silverado who was using a superchips handheld when his voltage dropped and the handheld shut off. Now his truck wont run. If I cant flash it to fix it he is getting it towed to the dealer.
    foff667
    Guest
    i had one guy have a similar problem where his handheld woudlnt recognize his computer after a flash so I tried to help him out by reflashing the stock file...hptuners wasnt able to read, write or full rewrite it...good luck...when they get fried they usually get fried pretty good lol.
    Oct 2004
    May as well give it a shot, not like it can really get much worse.
    EFILive is pretty good at recovering PCM's from what I gather. If the code that handles the communications is working you might be able to get it back. If not then you will probably be sending it to wait4me.
    Andrew
    EFILive Crew
    Jan 2006
    Yeah Im gonna try. Its just the truck is about a 30 min drive away. But if I get it to work then I sold a tune. If I don't get it to work then I sold a tune and a pcm, I just dont have any in stock right now.
    Jan 2006
    Well it DOA. A hanheld claims another one.
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    DOA with a full flash?
    Recovered several PCMs that were toasted by handhelds without any problems by using a bench harness and full flash.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Jan 2006
    Even with a full flash it wouldnt do anything. It said the pcm would not respond.
    Sep 2003
    Did it come up with something like "PCM doesn't have a valid calibration, yadda, yadda, yadda?" If so, did you stop at that point or try to actually flash? Is the voltage 12.8 or above?
    Depending on what point the handheld stopped it might be a door stop.
    They really only need to be programming for about 5 seconds to make it recoverable. If the handheld erased the flash and that is it, then it's a chip off repair job.
    Jan 2006
    Quote Originally Posted by SinisterSS
    It said all that but I tried to do a full flash anyway.
  1. Replies: 5
    Last Post: November 6th, 2006, 04:00 PM
