Results 1 to 3 of 3
Thread: How to do text strings in enumeration field?
    Mar 2007
    Default How to do text strings in enumeration field?
    I am creating a CAX file and want to use a text string for the enumerations field. Everything works fine until I put in a space in the text string. Is there way to make it so the enumeration description can have a space in it?
    Examples:
    This works:
    SI_ENUM = "0=Option1,2=Option2"
    This one does not:
    SI_ENUM = "0=Option 1,2=Option 2"
    What is the trick to allowing spaces in the enumeration field?
    Dec 2013
    You need to SI_ENUM = """0=Option 1"",""2=Option 2"""
    This also works in the SI_ROW and IM_ROW fields.
    Mar 2007
    Thanks, that works!
  1. no options text found
    By minytrker in forum FlashScan V2 BB Logging
    Last Post: October 10th, 2009, 06:05 AM
  2. Option Text not Found
    By Jason S. in forum FlashScan V2
    Last Post: December 20th, 2008, 08:22 AM
  3. FlashScan V2 field testing underway
    By Blacky in forum FlashScan V2
    Last Post: September 28th, 2006, 10:34 AM
