Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Known Issues With Current Public Release
    Default Known Issues With Current Public Release
    Latest updates (released as an auto-update):
    • EFILive V7 software: V7.5.10.323 (updated Feb 19, 2017)
    • EFILive V8 software: V8.2.5.316 (updated Feb 19, 2017)
    • Boot Block: V2.07.007 (Feb 07, 2014)
    • Firmware: V2.07.113 (Feb 19, 2016) (updated Feb 19, 2017)
    Updates are described here: What's New
    Use these links to download the latest version:
    EFILiveV8.2.5.316_Setup.exe
    EFILiveV7.5.10.323_Setup.exe
    Issue 1:
    Workaround:
    None.
    Issue 2:
    Workaround:
    Issue 3:
    Some LS1B tune files report "Controller type cannot be determined" when opened in the V7.5 software.
    Workaround:
    Update to V7.5.9 build 322.
    Issue 4:
    After Issue 3 was fixed, the software and firmware numbers were out of sync, causing the V7.5.9.322 V7 software to be detected as incompatible with the V2.07.112 firmware.
    Workaround:
    All version numbers have been re-synchronized.
    Please update to:
    Version 7: V7.5.10.323
    Version 8: V8.2.5.316
    Firmware: V2.07.113
    Issue 5:
    The full-flash and cal-flash counters in FlashScan and AutoCal are not updating when flashing controllers via the V8 software. They only update when flashing via the V7.5 software.
    Workaround:
    None. Will be fixed in the next update.
    Dec 2014
    New version now shows this on various files that open fine on previous version.
    Does it only occur on LS1B files?
    Can you send me a file that causes that error message?
    Dec 2014
    Here is one.
    LS1B.ctz
    Thanks, A patch will be available to fix the problem in the next hour.
    Quote Originally Posted by Team208Motorsports View Post
    Update has been posted to fix that issue, download the updated V7.5 software here:
    EFILiveV7.5.9.322_Setup.exe
    Dec 2014
    Fixed, thanks!!
    Jan 2017
    I have updated to V7.5.9 build 322, V8.2.4.315, firmware V2.07.112 (Feb 14, 2017).
    Controller: LS1B
    Issue: When I open V7.5 Scan Tool, it cannot connect to the controller. It states that it is incompatible with the firmware and to update both V7.5 and V8 (which i have done).
    I generally use V8 to flash the tune and V7.5 to log data.
    Please advise.
    Quote Originally Posted by recrit View Post
    Controller: LS1B
    Please advise.
    I will post an update in about an hour to fix that.
    May 2010
    Waiting for the update
    EFILive Tuner
  1. Known Issues With Current Public Release
    Last Post: February 17th, 2017, 07:06 AM
  2. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 12:02 PM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
