Results 11 to 20 of 26
Thread: Known Issues With Current Public Release
  1. #11
    Lifetime Member wesam's Avatar
    May 2010
    Thanks Paul its working now
    EFILive Tuner
  2. #12
    Jan 2017
    Thanks Paul! The update worked for me too.
  3. #13
    Dec 2005
    Is V315 available anywhere ?
    I have heard of issues with V316 and want to avoid any on LML and Cummins flashing, was told 315 was stable.
    www.mscservices.net
  4. #14
    Quote Originally Posted by GMC-2002-Dmax View Post
    V8 builds 314 thru 317 and V7.5 builds 315 thru 324 are all still available for download.
    Just edit the build number in the download links to get the version you want/need.
  5. #15
    Well Tony only one user is reporting issues with V316 (and they are very, very strange things), if you know of any issues with this version yourself please let us know, if you know of others having issue with that release please let them know to contact us.
    Thanks,
  6. #16
    Dec 2005
    I have a shop that is trying to flash a LGH, it flashed, after several attempts, then after a successful CAL flash a dead key-no crank-no start condition.
    They were able to roll back to 315, and the truck left the shop with an H&S installed until they get it back.
    I am still on 309 and will not update until a RC or Public Release is out for a while and stable.
    Hope that helps.
    www.mscservices.net
  7. #17
    It would help if we had trace files, that is the only possible way we can see what might have gone wrong
    FWIW others are telling us the current release is stable and good on all platforms so it is a hard job juggling issues that might exist for some but not others.
  8. #18
    Dec 2005
    The flash failed those times even with V315, when the truck returns to the shop I will provide the trace files.
    Thanks.
    www.mscservices.net
  9. #19
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    Paul, how do we download version 309? I've been using this without any issues but an employee just updated to 315 and I'd like to go back to the 309 version because I don't want to update firmware on the V2 and be stuck.
    Thank you,
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
  10. #20
    Apr 2006
    Quote Originally Posted by IdahoRob View Post
    Thank you,
    Never mind Paul, we have a saved copy of the software.
  1. Known Issues With Current Public Release
    Last Post: February 17th, 2017, 07:06 AM
  2. Known Issues With Current Public Release
    Last Post: January 31st, 2017, 12:02 PM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
