Results 1 to 10 of 11
Thread: 12216125 os current for 4l60e need match for 80e segment swap
    Oct 2015
    Default 12216125 os current for 4l60e need match for 80e segment swap
    02 4wd tahoe currently 12216125os checked drop box with no luck does anybody know where i can find a matching os for a 80e to do a segment swap, and then i have a efi live and i have 0 experience if someone could tell me where i can find information on doing the segment swap from the beginning, alot of information assumes i would know the basics but i dont any help would be extremely helpful thanks in advance
    There may not be a 12216125 4L80E file... you may have to run a 12212156 4L80E file instead.
    Oct 2015
    Thanks i appreciate the reply, i searched all weekend and when i would try to open a different os number for comparison, my unit told me it was wrong and wouldnt open it, so i ordered a harness that will operate the 80 off of the 60 tune hopefully it works as it says it will thanks again
    Aug 2011
    Quote Originally Posted by james workman View Post
    Sorry for the late reply.
    The 2002 Express van with an L31 5.7L engine had a 4L80E as an option. This should be in the database somewhere. If you can't find it, I can upload it.
    Oct 2015
    Quote Originally Posted by WhisperPC View Post
    Thanks but way to late if i had known before i wouldnt have ordered that 250.+ harness thats useless changed os and using an 80 segment now never the less your input is appreciated thanks
    Jun 2008
    I can't find this. I'm needing a 4L80e equipped 12216125 OS
    -John
    1991 RCSB 2WD Sierra LQ4 swap, 220/224 112 cam, Twin VSR 6766 turbos
    4L80e w/shift kit, PY 3600, and 3.73 gears.
    22 PSI and E85, 4300# with driver. 9.7@138, 1.47 sixty
    :drivin:
    Aug 2011
    Quote Originally Posted by LS1FREEK View Post
    Sorry about the delay. Here it is.
    Avalanche with the 8.1 had an 80E behind them, were DBW, and used this OS. You might need to bench flash a PCM, I havent found any tunes in EFILive format with this OS and 80E trans segment.
    Close... but he's looking for 12216125.
    Aug 2011
    Sorry. I must have misread the OS number ... twice.
  1. Going from 4L60E to 4L80E and keep 4L60E segment, relays mod, any help?
    By 400ss in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 1st, 2017, 06:06 AM
  2. 12216125 4l80 swap help
    By jj5star in forum Petrol / Gas
    Last Post: January 5th, 2016, 06:33 AM
  3. Just anothe 4L60E to 80E swap....
    By willn in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 17th, 2014, 11:22 AM
  4. 60e to 80e segment swap on COS
    By andysc3 in forum Custom Operating Systems
    Last Post: October 14th, 2012, 03:21 PM
  5. Need help building 80E file for OS 12216125
    By 1SlowHoe in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 15th, 2007, 12:51 PM
