Results 1 to 9 of 9
Thread: GM BCM bench wiring pinout
    Feb 2011
    Default GM BCM bench wiring pinout
    Interested in giving the newly released support a try but can't seem to wire up the BCM right. Anyone willing to share the pinout for a 14 C7?
    This release only covers (approx) 2006 to 2012 BCM's (made by Denso) Then after that GM split in to two BCM types, one made by Bosch, one made be Continental, those two aren't supported yet.
    Keep in mind, EFILive has only provided the flashing tool for the BCM, no mapping is available but modified tunes are available from Oz Tuner.
    Just an FYI, a BCM on the bench by itself needs a 120 Ohm load across the CAN bus before you can talk to it, or you can have an ECM hooked up at the same time for the same result.
    Feb 2006
    whoa, when did bcm reading get added in? must of missed that.
    It didn't, only BCM flashing was added by request of a company that wanted to sell already modified tunes for BCM's. Probably most of what they offer will be of little interest to Commodore owners knowing what options VE's had vs the Silverado trucks.
    Feb 2006
    yeah i've got no interest in it myself. just didnt see anything mentioned is all.
    I know a lot of the guys locally have just been able to send the relevant can command to change options etc
    Quote Originally Posted by Tre-Cool View Post
    In this "What's New" doc: http://download.efilive.com/Software/whatsnew_316.htm
    It says read/flash support because technically support was added for reading/flashing other controllers, it's just that reading is not implemented/possible on some controllers, i.e. the BCMA for which we've just added flashing support.
    Admittedly it is sort of a tiny little "notice" for a rather large enhancement.
    Feb 2011
    Thanks. Do you happen to have pinouts for one of those year BCMs?
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Quote Originally Posted by 1906 View Post
    Why do you need a pinout for the BCM.
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Nov 2005
    It was detailed in our recent newsletter and is on the front page of our website.
    https://www.efilive.com/latest/cat/n.../bcm-flashing/
    Cindy
    Sent from my iPad using Tapatalk
  1. CM2200 bench harness pinout
    By DURAtotheMAX in forum Cummins 6.7L
    Last Post: May 6th, 2022, 02:21 PM
  2. PCM Bench Harness Wiring diagrams
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2015, 05:51 PM
  3. Cam sensor wiring pinout
    By jet231 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 29th, 2014, 09:49 PM
  4. LBZ bench harness wiring diagram
    By boothybunch in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 18th, 2013, 04:46 AM
  5. Cummins Bench Harness pinout (pictures)
    By vortecfcar in forum Cummins 5.9L
    Last Post: September 2nd, 2012, 05:57 AM
