Does anyone know anything about this OS? Its for the 2016+ "Chevrolet" (Isuzu) low-cab-forward trucks. They have a 6.0/E38 and 6L90/T43.
I flashed (using TIS) an E38 I had lying around here using the VIN from a 2016 truck, and then tried reading out with EFILive, but it didnt seem to work...the ECM communicates with a scan tool, reads DTC's etc...so I assume the TIS/SPS flash worked fine. But the serial number, Calibration ID, and HDW number all show 000000000000 now.
VIN shows up fine, and all of the segment part numbers show up fine.
Did I brick the ECM? Are there only certain "special" E38's that work with this oddball 12658778 OS?
Ben
