I'm working on a tune for an LS2/T56/E40 swap. It has a terrible stumble off idle often times dying. Letting out the clutch initiates the stumble, slight surging, and then dying.
I've attached two logs and the tune file. I've included the frames to focus on the issue. What seems weird to me is the erratic and choppy swings in TPS. You can see the TP going up, yet the RPM is going down. Or RPM going up and TP falling down to 18-19% for a split second, then surging back up causing a yoyo effect. The surging is effecting everything like MAP, MAF, G/cyl, spark, fueling, etc, but I think it starts with the TPS activity.
Driving Log 3.efi
Driving Log 2.efi
Original Tune.ctz
Unfortunately, I did not log the APP and ETCTP, so it's hard to see how the correlation between the two. I can tell you I was not feathering the throttle, if anything, giving it more throttle as I let the clutch out. One last note, the VSS signal is not working properly. That's getting fixed now.
Driving Log 2 - Beginning at frames 1231, 1618, 1831
Driving Log 3 - Beginning at frames 414, 683, 1149, 1486, 1719, 1950
Anybody have thoughts on the TPS activity?
