hello everyone, new to tuning currently have a boosted ls7 with alky kit was tuned to 5 psi,
I have now upgraded the system and running 12 psi and straight meth with ait safety since meth is also being used as a fuel as well
issue im currently having is maxing out the maf by 5k rpm of freq 12800 and grams of 512's
been able to adjust the commanded afr and p.e. enrichment to keep afr around 12.3
I have a 101mm maf I can install to get alittle more play out of the maf but I don't know how I would adjust the fuel trim to compensate for the lower maf readings.
my other option is to go sd with a 2 bar map that I also have available to install
issue with either choice is limited knowledge on how to tune either of them,
my knowledge is pretty much limited to tuning with just the p.e and timing tables using lc-2 wideband and data logging
would anyone would have any links or write up's that I could use to research and learn with,
yes ive google searched for leasons but searching maf to sd tuning, how to tune sd ect... just comes up with
discussion's on maf vs sd or which is better.
and yes could pay someone of course to dyno tune it and not risk screwing up my car but where's the fun in not being able to tune your own toys,
just taking it slow and safe small changes each time
