Thread: adjusting fueling to compensate for 101mm maf or going sd
    Mar 2017
    Default adjusting fueling to compensate for 101mm maf or going sd
    hello everyone, new to tuning currently have a boosted ls7 with alky kit was tuned to 5 psi,
    I have now upgraded the system and running 12 psi and straight meth with ait safety since meth is also being used as a fuel as well
    issue im currently having is maxing out the maf by 5k rpm of freq 12800 and grams of 512's
    been able to adjust the commanded afr and p.e. enrichment to keep afr around 12.3
    I have a 101mm maf I can install to get alittle more play out of the maf but I don't know how I would adjust the fuel trim to compensate for the lower maf readings.
    my other option is to go sd with a 2 bar map that I also have available to install
    issue with either choice is limited knowledge on how to tune either of them,
    my knowledge is pretty much limited to tuning with just the p.e and timing tables using lc-2 wideband and data logging
    would anyone would have any links or write up's that I could use to research and learn with,
    yes ive google searched for leasons but searching maf to sd tuning, how to tune sd ect... just comes up with
    discussion's on maf vs sd or which is better.
    and yes could pay someone of course to dyno tune it and not risk screwing up my car but where's the fun in not being able to tune your own toys,
    just taking it slow and safe small changes each time
    Post your tune file and your stock tune file.
    There are several ways to scale for insufficient MAF or IFR range:
    - scale IFR, VE, MAF by r, and shift down any tables referencing mass (g) or flow (g/s),
    - scale IFR by r and Stoich AFR by 1/r,
    - scale IFR by r and one of the Injector Flow Modifier tables by 1/r,
    where r is some factor (e.g. 0.5).
    You will have to do the first one since your MAF table is range limited.
    Mar 2017
    Attachment 20813
    Attachment 20814
    attached is the stock tune file
    tune at 10 psi no meth and also my latest tune file at 10 psi with methAttachment 20819
    also I have a set of 120 lb injectors I can install but with such a big change from current 65 lb injectors
    I think it would be come a tuning nightmare to get straighten out atleast not intill I can get the air flow straighten out
    Mar 2017
    And just got done fabing up the 101mm intake
    Maf with duel m15 nozzles 1 inch farth downstream and then 2 inchs down stream is the ait, so if meth fails to spray ait goes up and timing gets pulled outClick image for larger version.
    Mar 2017
    installed the new 101mm intake adjusted the maf scaling by 33% and then adjust the iat scaling for the the gm iat sensor, did acouple runs and fine tunes runs pretty good
    i set the iat fail safe to start at .80 gram/s and above 30c the timing begins getting pulled and by 50c 10 degrees of time is pulled just to be extra safe if the meth fails to spary
    test run with meth activated iat temp went from 32c to 7c
    think I did a pretty good job attached is the final tune I installed took about 4 hours of trying and failing to get everything set right lol, it wouldn't even idle when I started itE38-2007 procharged meth injection 12 psi 3-5-17 101 maf final and iat-meth fail retard.ctz
    and if anyone is wondering this is a stock 2007 ls7 12-1 comp, 91 pump gas,12 pounds of boost, currently with no knock with 17 degrees of timing and straight meth
    so far once I get the tune cleaned up more ill push for closer to 22 degrees with a lot more meth
    Ok, you got it running good, good job
    what did you scale, MAF and IAT (doesn't your IAT pid now read wrong...?)...?
  1. Is there any table to compensate for bigger TB in E92 ?
    By wesam in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: November 21st, 2016, 09:20 PM
  2. How to compensate for larger injectors?
    By Zorganov in forum Duramax LB7
    Last Post: November 9th, 2016, 11:36 AM
  3. Replies: 5
    Last Post: May 19th, 2015, 03:06 PM
  4. adjusting MAF
    By n2brk in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 26th, 2014, 01:03 PM
  5. How to compensate for altitude changes in OLSD
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 10th, 2007, 03:32 AM
