Results 1 to 4 of 4
Thread: Questions.before purchase
    Feb 2017
    Default Questions.before purchase
    If I buy efi live how do the credits or etc work? My tahoe 411 is from lextech and am wanting to get into learning on my own.
    1. Do you license per vin?
    2.What if I bricked the computer does it.take more credits?
    3. If I wanted to play with my 04 tahoe computer how.much more is that?
    4. Is there any special cables for logging I may need or be aware of etc pieces to buy?
    5.what's the price of new aND can you buy used or how would that work?
    Thanks for your time anthoney
    1) You license per VIN (really it's per controller) before the first flash. You never have to license the same controller again with your FS V2. If you replace the controller or your buddy uses his V2, you will have to relicense it.
    2) If EFILive bricks the PCM, EFILive will evaluate the situation and possibly will provide you with a new VIN license. They will likely not pay for a new controller.
    3) Each PCM or ECM/TCM combo costs $125 for a VIN license. When you purchase a new V2, it will come with 2 VIN licenses ready to use. So, you could tune both PCMs with your initial V2 purchase.
    4) You have to buy the EFILive FlashScan V2 hardware with the GM Tuning option. It includes free access and updates to the V7.5 and V8 software packages. More info here: FlashScan V2 with the GM Tuning option
    Feb 2017
    awesome man thanks 1 more question I believe I read where the new efilive has like an auto tune where it can learn on its own to get a base line that's on the normal systen I would buy or is that additional. Thanks again
    Quote Originally Posted by anthoney456 View Post
    The auto tune you refer to would be AutoVE...
    you would need to buy a wideband to do this...
    you wire the wideband to the analog inputs on the FSV2 (or use serial comms if the wideband has a serial output compatible with FSV2);
    then you log a prescribed set of pids;
    then you use the software to do "AutoVE" which corrects the VE table (you do a manual copy/paste-multiply).
    There are other variations, such as AutoMAF, Calc.VET, Calc.MAFT.
  1. Pre purchase & Auto tune related questions
    By PeteS in forum Gen III V8 Specific
    Last Post: February 24th, 2017, 09:59 AM
  2. New Purchase Page Questions
    By ls1mike in forum Purchase and Shipping
    Last Post: August 5th, 2013, 12:17 PM
  3. Used V2 - purchase
    By flat_lander in forum Cummins 5.9L
    Last Post: January 11th, 2012, 03:34 PM
  4. How do I purchase RR
    By Harrismarine in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 8th, 2008, 12:16 AM
  5. Couple questions pre purchase
    By serpa4 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 1st, 2007, 08:00 AM
