I have been digging through some LS1B binary files trying to compare some of the differences. One thing that I am having some difficulty with is trying to determine whether or not some of the parameters are for a 4WD or not. When I open up the files in EFI Live, the initial configuration that you see under the VIN tab basically looks at the VIN #. Depending on whether or not the VIN listed here is the actual VIN of the vehicle, it could say 2WD or 4WD. I have noticed that you don't have to have the correct VIN in a PCM when you flash it. Thus, when you read it out, it could be a Corvette VIN with a truck tune. This means you are dependent on what the person who uploaded the binary file did when they read out the file.
This brings me to my question regarding how else can you tell if a vehicle had 4WD or not by looking at the other parameters in the file. I have found several, but it seems that GM did some odd things when they made these files. Example: There is a P1875 DTC which is a 4WD Low Circuit Switch parameter. If it is a car tune with a auto tranny, then this equals Yes. If the car had a manual transmission it equals No. All of the truck tunes (including Express vans) seem to have this as Yes.
Is there any other way(s) or parameter(s) to verify if a file came from a vehicle that had 4WD or not?
