Can a CM2100 that's locked by some unknown a̶s̶s̶h̶a̶t̶ tuner be flashed with a stock file? I know some controllers can be just not sure about this one or not. Don't want to waste a licence if I cant overwrite it.
Yes they can, the lock only blocks the reading function. If you have a suitable file you can flash over the top it should be fine to do so.
Awesome thanks!!
I am currently trying to write over a locked ecm but keep getting a 0537 error. Vehicle is a 04.5 dramas lly
Pretty sure the 04.5 lly blocks read and write. I don't think it was until the 06 lly/lbz that the lock only blocked reading (I could be wrong though).
Sent from my 2PS64 using Tapatalk
If you have access to a laptop, try using the V2 in pass-through mode with the EFILive V8 Scan and Tune software and check the two checkboxes: "Try Alt Keys" and "Assume Lock May be Faulty".
When you do that in pass-through mode the software will create a *.htx trace file in \My Documents\EFILive\V8\Trace. That is the trace file you need to send to EFILive Support.
2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
2017 Corvette 3LZ Z06 M7 with Z07 Package
