Results 1 to 3 of 3
Thread: DVT FAULT when trying to CASE RELEARN
    Senior Member Naf's Avatar
    Aug 2006
    Default DVT FAULT when trying to CASE RELEARN
    I am tryin to do a crank sensor relearn, and no matter which method i try i am failing.
    I tried EFILIVE and its giving me DVT FAULT,
    Parking brake engaged,
    Applied brake pressure
    engine at idle speed
    I even tried with the tech 2 and it doesnt identify the engine is running at idle speed keeps flashing, start engine and idle...
    I dont know what to do,
    I have a e67 swapped into an 05 CTS-V, i was able to do the Crank relearn the first time, before i had an issue with my BCM, but now it wont let me...
    HPTUNER also failed
    American Muscle, European Design, Japanese Tactics
    Feb 2013
    It is up to operating temp?
    Did you clear any DTC's before you started?
    When you start the CASE relearn, you have 10 seconds to bring engine speed up over 4000 rpm (i.e. by opening throttle)...
  1. Scan Tool DVT ECM Setup CASE
    By hapnermw in forum General
    Last Post: September 7th, 2013, 08:56 PM
  2. DVT Idle Relearn
    By Protec in forum E37, E38 & E67 PFI ECM's
    Last Post: October 19th, 2012, 04:25 AM
  3. Case Relearn
    By sheamus in forum Lounge
    Last Post: June 20th, 2009, 04:35 AM
  4. case relearn
    By 67LS3 in forum Gen IV V8 Specific
    Last Post: October 23rd, 2008, 02:52 PM
  5. CASE Relearn
    By Fratsit in forum General
    Last Post: February 7th, 2007, 10:39 AM
Tags for this Thread
