Results 1 to 10 of 12
Thread: E80 L4 SIDI how is boost increased what tables to change? 2016 camaro 2.0 turbo.
    Mar 2017
    Default E80 L4 SIDI how is boost increased what tables to change? 2016 camaro 2.0 turbo.
    I see it has P-I-D controller, are those graphs modified or other boost tables? Injector tables need tweeking after this? Thanks
    May I have a look at your tune file.
    Mar 2017
    guess I do not know how to move it here, guess I do not know how to move here I tried copy and paste and drag both
    At the bottom of this webpage, click Go Advanced, scroll down, click Manage Attachments...
    then in the Manage Attachments window that pops up, click Add Files, click Select Files, in the Open dialog that pops up browse to your tune file, click Ok;
    then in the Manage Attachments window click Done;
    complete your post (type at least 3 characters, click Submit Reply).
    Mar 2017
    Default stock tune
    jkhhg
    ( did I mean 5 chars? )
    ~Moderator~
    Mar 2017
    ~Moderator~
    Did you get file?
    Yes, I see it, I'll view it when I get home, thanks.
    ~Moderator~
    So you increased boost, but engine is otherwise stock...?
    ~Moderator~
    Mar 2017
    ~Moderator~
    no this is stock file I want to increase boost. I am adding charge pipes and downpipe cat delete and CAI and E85 flex sensor. I have a file I tried to increase boost with torque charts added 15% and added 8%timing but don't know if boost went up im installing boost gage sunday running stock tune putting in mine seeing if boost goes up. Its all stock now im waiting on charge pipes. im confused how to increase the boost on this.
  1. E80 L4 sidi flex fuel pin location 2016 camaro
    By david imgrund in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 10th, 2017, 02:46 AM
  2. E80 Boost target
    By Giambals in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 20th, 2017, 06:40 AM
  3. E39 SIDI L4 turbo
    By 3onic in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: January 25th, 2012, 11:54 PM
  4. Question About Holden sidi v/s American sidi
    By redonetoo in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 3rd, 2011, 11:59 PM
  5. Increased VE, little change in LTFTs?
    By 98WS6_JPM in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2005, 06:24 AM
