Results 1 to 7 of 7
Thread: No way to chose NONE in Scan with the Charts
    Jun 2003
    Default No way to chose NONE in Scan with the Charts
    When only wanting 2 of the 4 running, and attempting to modify and existing chart, there is no NONE.
    Could that be added?
    Jul 2004
    Two possible solutions. Make a new chart and only set up 2 items or set the color of the one you don't want to see to black. New charts come with nothing set so you can leave them blank.
    Ira
    Jun 2003
    Yah figured that one out, but kind of a pain if you want to quickly unselect something so you can unclutter a chart.
    Ugly way I figured out was to select a calc pid, add it to the chart, then remove the calc pid, the chart then shows the pid striked out and effectively cleans it up.
    Most likely now that I think about it, making a NONE pid is the way to fix that.
    Jun 2003
    Default I FOUND A WAY !!!
    DID IT!!
    Add to: 915 or whatever number above what you have
    Calculated
    *CLC-00-915
    % 0.00 0.0 .0 "0"
    Add To : Just chose any section just to get it in and f5ff to put it at the very end
    # Calculated PIDs
    CALC.BLANK F5FF CLC-00-915 % Fuel "Empty PID"
    Save your sae_generic.txt and reload EFILive
    Load your LOG, add this calc'ed PID in and then change the charts as needed now having a BLANK one if you just wanted to clean or quickly not have something in a chart on the fly without making a whole new one.
    Or just right click on the chart series' caption and select "Remove <xxx>" where <xxx> is the chart series' caption.
    Jun 2003
    :oops:
    DOH!!!
    Guess that will work too
    Jul 2004
    So obvious when he points it out, so hidden when he doesn't!
    Ira
  1. Replies: 5
    Last Post: January 8th, 2010, 05:53 AM
  2. IAC Charts
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: December 3rd, 2007, 04:39 PM
  3. Problems with upgrading V2 from scan only to scan and tune...
    By DngrZne in forum General (Petrol, Gas, Ethanol)
    Last Post: November 26th, 2006, 03:41 AM
  4. How do I turn on the charts?
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 6th, 2006, 12:32 PM
  5. downloaded 7.1.7 but charts still missing?
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2005, 09:21 PM
