Results 1 to 5 of 5
Thread: AutoCal is not recognized via USB to my computer $0280
    Mar 2017
    Default AutoCal is not recognized via USB to my computer $0280
    I cannot get my computer to recognize the AutoCal V8. I keep getting an usb error message that nothing is detected .
    The AutoCal works fine when hooked up to my truck. I can do reads and change tunes etc..
    It has a DTC error $0280 that I can't clear.
    Any help would be appreciated.
    Are you using a USB3 port? Try using a USB2 port and seeing if you can connect to it. I've had issued with USB3 ports not recognizing my V2 properly.
    Mar 2017
    Default USB 3 Error $0280 OBC is Fine
    My computer has 2 USB ports, I have tried both. I have connect the AutoCal many time without any problems in the past
    Go Start->EFILive->V8->EFILive V8 USB Manager, uninstall the driver, and install the older driver (2.02.04).
    Sep 2013
    where can the 2.02.04 driver be found? Or better yet, the 02.12.26 most recently recommended. Nevermind... loaded the Beta versions, thanks
  1. Uninstalling and reinstalling FlashScan/AutoCal USB drivers
    Last Post: December 22nd, 2023, 09:01 AM
  2. Error: $0280
    By Sonic4262 in forum Duramax 2011+ LML / LGH
    Last Post: January 29th, 2017, 12:32 PM
  3. Replies: 3
    Last Post: September 18th, 2016, 12:38 PM
  4. FlashScan/AutoCal USB Drivers: IMPORTANT INFORMATION
    Last Post: February 2nd, 2016, 05:23 AM
  5. ERROR CODE 0280 not conntected
    By speedo in forum General
    Last Post: May 12th, 2015, 08:46 PM
Tags for this Thread
