Results 1 to 8 of 8
Thread: Vats
    Apr 2010
    Default Vats
    Hi Guys,
    Has anyone been able to do a VATS delete to run the 2.8L standalone, Or will it be an option in further release's
    We haven't done them yet as nobody has asked, but it should be possible. Are you trying to do it at the moment or just planning a project?
    Apr 2010
    Planning a project at this stage, we have 3 engines sitting here and if we can make them run we have projects to fit them into. If you need someone to test it for you let me know and i can get the engines set up to run on a stand.
    It shouldn't be an issue for us to do it, if you wanted to set one up (yeah I know easier said than done) then we get make it work.
    Apr 2010
    No worries i will set one up and shoot you a message once its done
    Yep, just repost in here would be best.
    Thread mining as i did remember there was a request already.
    Picking up a wrecked 2014 colorado on friday, haven't really decided what to do with drivetrain yet, but figured it best to get in early and put in a request for vats parameters for OS 55597308 (at least that's what tis2web says it has for vin). Happy to test or run it on a later model OS's if you only want to do a certain os year.
    No problem, we did the VATS patch for two Opel OS's (not even the 2.8L) but I never heard back how it went.
    When you get closer to firing it up let me know, I can knock it over pretty quick.
  1. Vats
    By blackdeath in forum General
    Last Post: January 10th, 2017, 03:48 AM
  2. VATS help!
    By Dmaxxrus in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 24th, 2016, 07:25 AM
  3. Vats
    By shay in forum Duramax 2011+ LML / LGH
    Last Post: March 7th, 2015, 04:20 AM
  4. Vats
    By Yortt in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 12:21 PM
