Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Is the 411 PCM upgrade worth it for only basic mods
    Mar 2017
    Thanks, i will likely do the work to swap to the 411. I will work with my tuner who has experience with 98-00 BBC and likely go with whatever he suggests. At this point i don't think i am really interested in anything a COS upgrade has to offer, but i figured it may add some flexibility in the future? I will have to do some more reading thru these forums. After i do the 411 PCM, cam, headers and transmission, i likely wont be doing much else other than looking thru the maps for a little extra performance here or there and playing with the PCM inputs/outputs to control gauges/fans etc.
    Sounds good, then a stock OS should be just fine for you. Good to hear your tuner has more knowledge about this swap, I can help with the mixing/matching/mashing of tunes and how to get your base tune setup, but I havent done anything with a BBC before just LSx stuff with the 0411.
    Mar 2017
    Sounds great, stock OS it will be, thanks again for the help, you have saved me a bunch of time as i wanted to have this stuff roughly sorted out before i started pulling my truck apart.
    ( I don't know why the forum software was marking your 3 posts 'Moderated' (I didn't see any questionable url's) which makes them invisble... I saw that you posted the same material after that so I deleted those 3 moderated posts
  1. 96 to 411 pcm
    By tokymon in forum Vortec V6/V8 Specific
    Last Post: December 22nd, 2018, 01:11 PM
  2. is it worth paying to upgrade v1 to v2 just for serial wideband input?
    By ryans1000 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2011, 06:47 AM
  3. Worth the upgrade?
    By zapp168 in forum FlashScan V2
    Last Post: May 14th, 2008, 09:20 AM
  4. Upgrade to 7.5.1 worth it for LS1?
    By RevGTO in forum Gen III V8 Specific
    Last Post: October 10th, 2007, 12:57 PM
  5. 411 PCM's
    By joecar in forum Lounge
    Last Post: June 4th, 2007, 11:07 AM
Tags for this Thread
