Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: High Idle Feature... AGAIN!
    Mar 2017
    Default High Idle Feature... AGAIN!
    So I was reading something the other day that stated if you have the dealer turn on the high idle program on a STOCK tune, that when you pull the base file from the truck and use it to write EFI tunes that the high idle will still be enabled once the EFI tunes are installed in the truck.
    Is this true?
    If so, or if no one has tried it, I think I might just take the plunge and have the dealer wipe my truck and turn on the high idle feature with a brand new stock tune to boot. I know HPT has this option for the 03-05 trucks and that kind of makes me envious.
    If anyone can confirm this, maybe we could even just find someone who has a base file with the high idle enabled. But I guess there are several versions of the ECM software and we would have to have one of each for everyone to have access.
    My truck is an 07 5.9 BTW.
    Been snooping around here for a while, so I thought I would join and post up this *possible* idea of mine.
    Dec 2012
    Yeah it's true. Software OS doesn't really matter on the 5.9 and I'm sure most everyone is sending out the same OS to all their customers. PM me I can dig and send you a clean base tune with high idle.
    Sent from my iPhone using Tapatalk
    2005 Cummins - EFILive Conversion - S474 single - 1325hp on the spray.
    I have no idea how this system works, is it something the dealer turns on without needing to flash the ECM?
    Nov 2010
    Apparently this feature is stored in the NVRAM. And yes it's editable within the OS.
    There are several functions avail on the 03-05 tuning platform I wish we could get on the 06-09 trucks or the rest for that matter.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Mar 2017
    I guess I havent been on here long enough... PMs havent been turned on for me yet. My email is melonas22@gmail.com.
    Thanks a ton Cummins610!
    Quote Originally Posted by 2007 5.9 View Post
    Functions enabled via a scantool I assume you mean? Is there any aftermarket alternative to the DRB (or whatever it is called).
    Senior Member KhakiCummins's Avatar
    Sep 2011
    AutoEnginuity can enable the PTO fast idle on at least the 07.5-09 trucks. Not sure about the older or later ones but I would assume that it does those as well. I would imagine that the Snap-On tool probably does it as well.
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
    Mar 2017
    Quote Originally Posted by Cummins610 View Post
    Ill take that offer... I cant PM you, but my email is melonas22@gmail.com
    Your file is much appreciated sir!!!
    Nov 2015
    I have the high idle base tune for my 2006 I got off this forum. I think they are out there somewhere.
    So I'm getting mixed messages here.
    1 - The High Idle can be activated in the Tune (if the parameter is known).
    2 - The High Idle can also be activated with a scantool without the need for the ECM to be flashed.
    Is that correct?
  1. High Idle
    By DarkDiesel in forum Cummins 5.9L
    Last Post: December 28th, 2015, 10:56 AM
  2. High idle???
    By Dougal in forum Cummins 6.7L
    Last Post: September 12th, 2012, 12:42 PM
  3. high idle help
    By amiller406 in forum Duramax LB7
    Last Post: March 25th, 2011, 06:55 AM
  4. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 03:14 PM
  5. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 01:18 PM
