I need to make sure i am issue spotting before finishing wiring and going to the dyno;
I want a simple on off button for the fuel pump
simple on off for starter, as in it cranks as long and only as long as i hold the button down
I want a simple power on
I want a simple on off switch for the fan
such that the motor will fire and fun without any routines or modules
I wont have a brake switch connected, or if i absolutely have to have one it will be an aftermarket on off
this is an e38 out of an 08z, with a speartech harness, dbw, fast 102 tb,
basically just full time power button to the ecu, switched power, do i have to have a fuel pump input to ht eecm?, no speedo, no tach, (those are canbus to an aim unit)
I sure would appreciate any advice
