Results 1 to 10 of 12
Thread: wot 2-3 shift on limiter
    Jan 2013
    Default wot 2-3 shift on limiter
    I am running into trouble with a 6.0 4l80 combo hitting limiter on 2-3 shift it is not being commanded I've tried everything i can possibly think of wot set to 4800 I've tried 4000 it just wont command until 93mph I am running it in 4 low 5.13 gears reading from trans output vss wondering if its just not possible for the pcm to shift fast enough. tune and log posted 0411 512k cos
    I'll look at your tune when I get home.
    In your tune did you correct the speedo for your gear/tire...?
    ~Moderator~
    Jan 2013
    ~Moderator~
    Yes but it reads wrong when I'm in low range which shouldn't bother anything I just sold my other jeep with the same setup but 4.10 gears and 1mb pcm that worked fine
    Jan 2013
    If you look at the log commanded gear it's on limiter for a while before it even commands 3rd, pcm too slow? I'm stumped and I race up a snow hill in a week. might try changing to a 1mb. one thing I forgot to do was Dvt control I'll try that when I get home tomorrow.
    The PCM is not slow, it's being fed incorrect data and/or its tables are incorrect.
    ~Moderator~
    Jan 2013
    ~Moderator~
    So you obviously see something wrong in the tuning side of it? I've done a bunch of logging and tuning what should I be logging that I'm missing?
    Jan 2013
    nobody? nothing surely there has to be a fix for this? I've searched everywhere Ive tried all I can find
    Sorry, I have been delayed... I'm still looking thru your tune file.
    What axle ratio and what tire size do you run...?
    Jan 2013
    I have 5.13 gears 35" tire like I Said before I am running 4 low but reading speed before transfer case. I have a race Saturday and am pulling my hair out. if I let off throttle slightly at the right time it will shift, any help would be much appreciated thanks
    Your WOT upshift/downshift MPH values are upside-down, including the WOT 2->3/3->2 values
    the downshift MPH has to to be lower than the corresponding upshift MPH
    e.g. your D0930,31,32,64 are set to 60,60,66,30; your D0915,16,17,67 are set to 20,20,55,25; these are upside-down, this will prevent WOT upshift in any mode of the 4 modes.
    Same with your PT 1->2 and PT 2->1 tables.
  1. wot shift
    By danny68ss in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2015, 08:19 PM
  2. Boost or RPM limiter? Won't shift....
    By LBZoom in forum Cummins 5.9L
    Last Post: July 5th, 2014, 11:26 AM
  3. E67 weird timeing drop @ WOT before the REV limiter
    By wesam in forum E37, E38 & E67 PFI ECM's
    Last Post: May 12th, 2014, 09:51 AM
  4. WOT Shift, 1-2, 2-3
    By arubenstein in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 25th, 2008, 01:24 PM
  5. Hitting the rev limiter on the 2-3 shift at WOT...
    By waveoff in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 14th, 2007, 11:23 AM
